15x8 w/4.5 inches of backspacing for the track?
Old Jun 18, 2006 | 04:17 PM
GONE's Avatar
Hey guys, I searched, but wanted to know if this wheel offset will work on our cars.
I am going to run a 26 inch slick, and the offset on the wheels is 4.5 inches.
Will I encounter any problems?
Old Jun 18, 2006 | 04:19 PM
95z28_'s Avatar
Re: 15x8 w/4.5 inches of backspacing for the track?
No everthing should work ok!!!!!
Old Jun 19, 2006 | 09:54 AM
Your tires will be slightly outside the fender. You need a 5.5" backspace on an 8" wide wheel to keep the tires completely under the fender. They will stick out about 1" more than these:
Old Jun 21, 2006 | 07:23 PM
mongse_1's Avatar
It'll have a nice REO Speedwagon look to it.
Old Jun 22, 2006 | 01:18 AM
GONE's Avatar
My bad, I meant to say 5.25 inches of backspacing.
They are Cragars, not Welds, and that is the best/closest I can get to 5.5 that I know of.
-Matt
Old Jun 22, 2006 | 08:42 AM
Then its only going to stick out 1/4" more than the photo above, and if you don't use a really huge tire they probably won't stick out any more than the photo above. That photo is a 28x10.5-15W ET Drag, which is a pretty meaty tire. (The photo also is a 15x10" 7.5" backspace wheel, but the outside edge sits the same place as a 15x8" 5.5" BS wheel).
Old Jun 22, 2006 | 11:13 AM
GONE's Avatar
Anyone think I'll have problems with a 26 inch tall tire, being that my car is lowered with the Eibach Sportline springs........
Old Jun 22, 2006 | 11:18 AM
mongse_1's Avatar
The 5.25" BS will work well. I had a 5" b/s on my old Centerlines and they fit a 26" tire just fine.
Not since the cars come w/ just under a 26" tall tire from the factory. If you mean 28, then you might have to do some hammer work on the inner fender well and possibly roll the lip of the fender.
Old Jun 23, 2006 | 03:27 PM
GONE's Avatar
Good.
I already rolled my fender lip and did some hammer work because I used to have 315's out back.
So I shouldn't have any probs.
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
Noct
Jul 14, 2015 01:18 AM
birdblack
Jul 8, 2015 07:23 AM
mongoose=
Mar 22, 2015 07:22 AM
