Need clutch alignment tool in SA
Old Sep 6, 2004 | 11:34 AM
Barry00Z's Avatar
I am changing out my clutch and I have everything back together, but I can't get the trans to align with the pilt bearing and clutch. I am in need of an alingment tool and can't locate one. If you are in San Antonio and know where I can get one, please send me a messgae.
Its for a 2000 Z28.
Old Sep 6, 2004 | 11:54 AM
nitrojunky's Avatar
Re: Need clutch alignment tool in SA
dunno how much you tried, but I've installed my T56(s) several times w/o an alignment tool... I just eyeballed it very carefully before tightening the pressure plate & installing the bell housing,, then put the tranny on my chest, lifted the tranny, slid the splines thru the pressure plate, and 'worked' it around some until it slid into place (into the pilot bearing)... sometimes it takes a couple of realignments... I used to have one of those plastic alignment tools (bought it the first time I pulled the tranny), but quite honestly it was too flixible to align the stuff properly and actually did a worse job than I did 'eyeballing' it.
disclaimer: don't try to lift a ~150 lb tranny over your chest in an awkward position if you think you may drop it/hurt yourself/pop a hemorrhoid
hope this helps a little
marlar98
Sep 12, 2018 07:18 AM
Ericksd
Jan 20, 2016 06:07 PM
Jake Bialke
Sep 24, 2015 11:31 AM
Ericksd
Sep 16, 2015 07:08 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
