Looking for a driveshaft.
Old Apr 9, 2006 | 01:35 PM
snakeatinZ's Avatar
Lmk what you have. Steel or aluminum?? I prefer aluminum.
P.s. new 12 bolt went in the car (m6) and the pinion angle is outon the rear end, causing the driveshaft to smack and rub the e. brake line bracket in the tunnel of the underbody. How do you lower the angle of the rear end, ( the pinion angle) Adj. lower control arms? Relocation brackets? The drive shaft is TRASHED! Mabey I can get some pics up soon.
SteveO
Old Apr 9, 2006 | 02:22 PM
Josh'95Z28conv's Avatar
Re: Looking for a driveshaft.
Why would anyone with a 12 bolt want an aluminum driveshaft?
Old Apr 9, 2006 | 02:41 PM
69gto96z's Avatar
I have an aluminum driveshaft that needs a yoke and u-joints. I will sell it real cheap if you are interested.
Old Apr 9, 2006 | 03:19 PM
snakeatinZ's Avatar
idiot!
Old Apr 9, 2006 | 03:21 PM
snakeatinZ's Avatar
Ls1, 1le, Price? Thanks for the help.
Steve
Old Apr 9, 2006 | 04:02 PM
Originally Posted by snakeatinZ
idiot!
Excuse me? You obviously have no idea what you're talking about. ****ing idiot.
Aluminum driveshafts are weak. I would never run one with a 6 speed and a 12 bolt if you ever plan on hooking up. I twisted one at only 300rwhp. The stock steel LT1 shaft is much stronger. IMO, the aluminum driveshaft swap is the dumbest mod ever
Old Apr 9, 2006 | 04:39 PM
snakeatinZ's Avatar
If you do not have a driveshaft for sale, or can help me with the angle on my rear end stay out of my post.... I will take your mother out on a date and never call her agian.
Steve
Old Apr 9, 2006 | 06:59 PM
Desertrat's Avatar
SteveO
The best way to adjust the pinion angle is with an adjustable torque arm. You can get the tunnel mount or the tranny tailshaft mount. Tunnel mount transfers a lot more noise and vibration, and depending on style can kill ground clearance but is stronger, and most come with a ds loop option, a good idea with a 12 bolt. Its seems a little wierd to me that your pinion angle is that far off with a rear swap, Strange and Moser should work fine with the stock torque arm. Might be an installation issue you missed?
Personally, I'd spend the money on a new DS. Spohn or Dennys arent too pricey - you dont want to buy someone elses problem.
Old Apr 9, 2006 | 07:25 PM
Steve
Ok, Ill let you **** your money away on stupid ****. I thought Id give you a little advice, since its obvious you need it, and you have to start talking ****. If you use an aluminum driveshaft, and if you dont know how to adjust your pinion angle, you are a dumbass, and should let others who know much more about this kind of stuff give you some advice. Good luck on getting 10's out of anything you drive
Old Apr 9, 2006 | 09:04 PM
snakeatinZ's Avatar
ahhhh... You lost your temper... where is your sence of humor?? Ill get that time slip in the mail to ya. Thanks for the advice ill be going back with a steel driveshaft.
Old Apr 9, 2006 | 09:14 PM
I do lose my temper when Im called an idiot. I simply asked why anyone would want to put an aluminum driveshaft in anything modified. Its crazy if you ever plan on hooking up, let alone running 10s.
I had my stocker balanced with new u joints, and had the slip yoke welded because it was leaking out the center, for under $110, and the shop said it should hold 500HP. An aluminum piece wont hold near that.
Old Apr 9, 2006 | 10:21 PM
snakeatinZ's Avatar
good idea!
Old Apr 10, 2006 | 01:28 AM
blksunshine's Avatar
have a stock steel of a lt1 car make offer
Old Apr 10, 2006 | 01:32 AM
Domster_ss's Avatar
get a carbon fiber one from www.tpis.com
Old Apr 10, 2006 | 05:42 AM
snakeatinZ's Avatar
does it matter A4 or M6? The car it would be going on is a m6. $40.00 if it has all u joints and yokes.
Steve
