Fs lt1 tti turbo kit
ok a have a tti style, (not sure if its a true tti or someone made it) i bought it from Daniel @ SQR in dallas. the turbo is a 76mm, im getting bout 8-9 psi with the wastegate and cant find any springs for it. but a mbc will work on it. down pipe is 3.5, i custom made 3.5 exhaust all the way over the axle if your interested in that also. i wasnt runnin a front sway bar. and you dont have to move the radiator or any thing. it could use a coat of paint or coating, this setup can prolly make around 600 at the wheels. im sure im forgetting some stuff,,,,,,2500 obo!
what turbo is that?....also...whats the hot side AR?
is that flange warped?
where in Austin are you?
I would like to take a look at it... thanks
LT1runner
33
Jul 24, 2002 01:19 PM
