FS: LT1 stuff
Old Jan 26, 2007 | 09:15 PM
whitehooptie's Avatar
FS: LT1 stuff
All prices are best offer.
Hooker Long tubes uncoated with o2 bungs = SOLD
BBK 52mm TB, ported a little = SOLD
Brand new never used CSI Electric water pump on a housing SOLD
Spec Aluminum flywheel, not too many miles, but has hot spots you can buy a new mating surface for about $60 = $250
Aeromotive AFPR diaphram is busted $40 to fix it = $50
Shortblock, spun rod bearing everything is there: front cover, cam is the comp 236/242 i forgot the lift, somewhere on the side of the 306, on a 111 LSA $300 obo
Heads if anyone is interested. Stock ported. Never got them flowed. The car made 399 RWHP on a wore out bottom end and the 306. Felt the same with the cam that is in there now, just never got it dynoed. Has 7/16th studs, isky adjustable guide plates, comp 987 outer springs with some Lunati inners, pretty stout, 10 degree locks and retainers. Probably needs a valve job. Has maybe 10k miles on the heads right now. $600
LT4 hotcam only. Couple of surface rust spots, but will clean up = $125
I know I have some other stuff, just have to get to it. I'll try to get some pictures if anyone is interested.
I need some LS1 stuff. Will consider trade, need idler pulleys, a/c stuff, mounting brackets for the accessories, motor mounts, Kmember, any performance stuff. Starter, bellhousing. Let me know what you've got.
Old Jan 27, 2007 | 07:44 AM
95z28racer's Avatar
What year do the headers fit for?
Old Jan 27, 2007 | 07:53 AM
snakeatinZ's Avatar
How much for the short block?
Old Jan 27, 2007 | 08:48 AM
69gto96z's Avatar
I have an LS1 k-member and am located about 10 minutes from greenville. Give me a call, 214-893-3625 if you are interested.
Old Jan 30, 2007 | 12:14 PM
Biggergriff96TA's Avatar
can you sell the plug that plugs into the temp sensor on the driver side of the block mine broke and i cant find it anywhere let me know.
Old Jan 31, 2007 | 01:44 PM
AdioSS's Avatar
West South Central Moderator
how much for the shortblock?
Old Jan 31, 2007 | 10:18 PM
I'll go to my dealership and see if they have more. If they do, I'll buy one and ship it to you. No extra, just what I paid for it and shipping. I'll let you know tomorrow. Now by the side of the block you mean the driver side cylinder head correct?
DirtyDaveW
Dec 1, 2016 05:37 PM
Fatdog2
Feb 13, 2015 08:19 PM
Jlo
Feb 3, 2015 09:41 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
