can anyone in San antonio help w a couple probs?
Old May 20, 2004 | 12:44 AM
Donohue96M6Z28's Avatar
ok im about to leave on a trip, and im takin my car, and i have a copuple problems, the first problem is when i turn the wheel slowly to the left and go at a slow speed the left tire makes a popping sound, like something is popping out then pops back in...my 2nd problem is i changed my radiator a couple months ago, and the low coolant light sometimes is off, sometimes its on and turns off sometimes, and sometimes it blinks every 2-3 seconds really wierd i havent seen that b4, and the coolant level is fine in the reservoir and in the radiator, any one know what the problems could be?? or can anyone in SA maybe take a look for me and maybe even fix it?
thanks
patrick
Old May 20, 2004 | 07:44 AM
the right formula's Avatar
As far as the coolant light, I had the same problem shortly after I bought my car...they just replaced the sensor and it's been fine ever since. Don't know what to tell ya on the popping noise though...CV joint maybe
Old May 20, 2004 | 08:24 AM
ShaneS's Avatar
98s did have a problem with the low coolant sensor. I'd replace it if yours is a 98.
As for the popping...dunno...sounds silly, but the lugs are all on tight, right?
peace...
Old May 20, 2004 | 09:16 AM
how many coolant sensors r there?? are they hard to change? how much did they charge to replace it for u?
Old May 20, 2004 | 10:00 AM
TxAgZ28's Avatar
Originally posted by the right formula
CV joint maybe
Old May 20, 2004 | 06:21 PM
xxFastTransAmxx's Avatar
popping can also be the wheels hub
Old May 20, 2004 | 06:40 PM
Old May 20, 2004 | 08:40 PM
the wheel hub has a bearing in it and it can go bad. my t/a once had a popping noise and it turn out to be my passenager side hub.
Old May 20, 2004 | 09:46 PM
how much do those run for? alot right?
Old May 21, 2004 | 01:18 AM
lt1ownsall's Avatar
open hood
under the fill cap is a sensor
just unplug it
no more light
Old May 21, 2004 | 01:21 PM
gun4hire's Avatar
I had that same popping for some time. Did the front brakes with new rotors/pad - noise gone. *shrug*
I would def have it checked before your trip.
Old May 21, 2004 | 01:58 PM
KyleBlue85Iroc-Z's Avatar
As far as the coolant sensor goes:
Either do this: http://shbox.com/1/low_coolant2.jpg
or
Unplug it like stated above and just keep closer attention to your temp gauge (just in case you do have low coolant).
I can't really help you with the noise though. Good luck with it. Definately get it checked.
Kyle
Old May 22, 2004 | 01:06 PM
orangeapeel's Avatar
Check your bearings, and grease up your front end if you can.
Possibly the CV joint.
Old May 22, 2004 | 03:48 PM
AHARTZ28's Avatar
the pop sounds like a lower balljoint worn. if it breaks hold on the tight . i would get it fixed
Old May 22, 2004 | 10:25 PM
***Makes the noise when i turn right too, not sure if that means anything..lol..probalby gonna go it checked out tomrrow hopefullly its nothing big
and hey ryan, i saw ur impala and bird out at the forum, awesome cars man
Sep 27, 2015 01:55 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 17, 2015 09:50 AM
