what is normal oil pressure for our 6s?
Old Apr 10, 2003 | 10:54 PM
94 green drop top's Avatar
I have a 94 v6. what is normal oil pressure? im reading ~40 on the gage, to about 20-25 during highway use, and around 5 idling (which sounds about right).
Old Apr 11, 2003 | 09:13 AM
camaros_4_lfe's Avatar
around 5psi or 50 damn thats low i would get that checked with a oil pressure gauge at a shop unless it is 50
mine never goes below 40 and stays at about 75 when cooler and 65 when warm
get it checked now!!!
even on old cars the rule of thumb is atleast 10 psi for every 1thousand rpm
Old Apr 11, 2003 | 01:38 PM
BradC's Avatar
Mine holds steady @ 75-78 when @ 60MPH. 55 @ idle.
Old Apr 11, 2003 | 04:24 PM
MustangEater82's Avatar
Replace your oil pressure sensor...
Mine was readding real low, busted and I was losing a quart of oil every 70 miles...
I replaced it and my pressure doubled.
At cold start up I am near 75psi, once car warms up I am around 50-60psi.
Old Apr 15, 2003 | 02:09 PM
is the oil pressure sensor the same as the oil pressure sending unit? i replaced that not too long ago...
Old Apr 16, 2003 | 08:36 PM
TheV6Bird's Avatar
So out of the gauge's maximum of 80 PSI, you are reading 75-78 PSI? That is high as hell.
When the car is cold, I read somewhere between 50-60ish. Normal highway cruising I am at 40 PSI. When it gets hot, that is when the pressure drops. I am around 5 at idle, after driving around for a while.
Old Apr 16, 2003 | 09:27 PM
When it gets really hot, and chilling in traffic, my pressure goes to maybe 25 psi at the lowest at idle.
Isn't 5psi in the red?
Old Apr 18, 2003 | 10:20 AM
fbird95's Avatar
You guys have some serious changes in pressure in your cars. Mine does not move like that and never goes anywhere near 80 psi and never lower than just below the center mark. We must consider that GM's gauges arent exactly meant to be the most precious gauges.
Old Apr 18, 2003 | 01:48 PM
Well mine is somwwhat new so i kinda trust it.
it shoudl move, oul pressure goes up when the revs go up. Also is affectd by how hot or cold it is.
either way under 20 psi I think your sending unit is bad or your car has issues, most likely the sending unit.
Old Apr 18, 2003 | 06:56 PM
fbird95's Avatar
My gauge fluctuates all the time, Just not in a range from 20-78 psi.
Old Apr 19, 2003 | 12:39 AM
97QuasarBlue3.8's Avatar
This topic has been brought up a few times on this board and others. Having owned a 3.1L and a 3.4L, I can vouch for low oil pressure readings. I don't remember the numbers exactly, but when the car was warm, it would hover around 1/4, and when cold it would be around 1/2. I used 10w-30 oil too.
The 3.1L never burned or leaked in the 170,000 miles it was alive. The 3.4 was still running very strong when I sold it at 70,000 and it didn't leak or burn either.
Just as long as it doesn't go into the red!
Old Apr 19, 2003 | 02:18 PM
BradC's Avatar
Yup. It never drops below 37 PSI. Even when the car is hot it still holds steady at 65-70 PSI. 42 PSI in park.
Old Apr 19, 2003 | 09:49 PM
oil pan 4's Avatar
With 4 qurts of oil...
0psi in a hot 2.8 when coming to a stop.
14-15psi when ideling hot.
That engine didn't last to much longer after I started seeing those numbers.
Old Apr 19, 2003 | 11:55 PM
#7's Avatar
55 in park,cruising 65,with some throttle it'll jump to 70
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
