what could be the problem?
Old Nov 11, 2003 | 08:53 AM
DontMixWithRice's Avatar
i have had 18's on my car for about a year now, and I recently (sunday) changed the front tires from 245/40/18 to 245/45/18. When i changed the tires, the mechanic told me that my right front disc brake was worn out. I thought, no big deal, and would change it the followign week. now....as soon as i put these new- used tires on, the car started shaking horribly. @ 45 the steering wheel is shaking, but the car stays straight. it has been like this ever since...especially @ low speeds. WHat could be the prblem? thanks!
Old Nov 11, 2003 | 11:14 AM
ImportKILLER's Avatar
Check to make sure everything was put on correct.
If it has vibration, the tires might just need to be balanced? You did say they were used, right?
Old Nov 12, 2003 | 02:05 AM
oil pan 4's Avatar
Make sure your frount wheel bearings don't have to much play in them too.
Old Nov 12, 2003 | 08:21 AM
first, thanks for all the help. well, i found the problem...the rim is dented, and the balance is horrible. i am going to need to reshape the rim...
Old Nov 13, 2003 | 09:04 AM
deadmeat2004's Avatar
if its just one rim then id buy a new one, just me
Old Nov 13, 2003 | 11:08 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
a dented rim usually dosent cost too much to fix, a new 18" rim.. thats not cheap
Old Nov 13, 2003 | 12:42 PM
well how do they fix a dented rim?, i was just saying that that is what i would do, seem safer to me.
Old Nov 13, 2003 | 02:04 PM
down in miami, they are chargin me between 85 and 100 to str8n out the rim. The rims are about 350 a piece, simply because they are custom. The worst part is, i have no idea how the hell i dented it to begin with. it is dented in the inside part of the lip!!! wtf?!?!?
but again, thanks again for everybodies help
Old Nov 13, 2003 | 04:18 PM
atl2001's Avatar
big pothole is my guess...
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
