What clutch should i get
Old Mar 27, 2004 | 03:23 PM
95camaro3400's Avatar
im gonna do some internal/external modding to my 3.4 and i need to kno what clutch u guys reccomend. I was looking on ammperformance.com and the stage 1 will hold 400 hp i kno i wont have that much so u guys think it'll work fine? if not what clutch u guys reccomend
p.s. mods im planning are headers, pulley set, k&n intake, lunati cam (ammperformance, only lunati for 3.4), 1.6:1 roller rockers, ported heads and plenum, lt1 throttle body.
Old Mar 27, 2004 | 03:24 PM
can anyone give me just a guess of my hp numbers at engine and wheels after these mods
p.s. also have flowmaster exhaust, and my tranny is manual
Old Mar 28, 2004 | 02:53 AM
oil pan 4's Avatar
To much clutch and you will trash the trans or rear on your car.
Most likely the trans I dont think the trans on out cars is real strong.
Just ask the DSM turners they know a lot about replacing transmissoins.
How ported will the heads be?
What ate the #'s on that cam?
What springs will you use?
Tell what the cam #'s are and I can tell you what I think it might get you.
An after market cam (any one worth buying) and 1.6 rockers all ways means your stock springs will have to go.
Old Mar 28, 2004 | 04:23 PM
it is the lunati-30000
Lunati Hydraulic Flat Tappet Cam - High Performance
SPECS
Intake
Exhaust
Duration @ .050
228°
228°
Valve Lift w.1.5 Rockers
.465
.465
Lobe Seperation Angle: 110°
Intake Centerline: 106°
$165.83
and the comp cams valvetrain package
which includes CompCams 1.6:1 Roller Tipped Rocker Arm/Hardened Pushrod Kit
(RP1414.12)
- CompCams Hydraulic Flat Tappet Lifters
(802.12)
- CompCams Valve Springs
(980.12)
- CompCams Valve Spring Retainers
(742.12)
CompCams Valve Locks
(601.12)
and
3.4l powerpack heads and intake from supersixmotorsports.com
thx
Old Mar 28, 2004 | 04:25 PM
im looking for a cam that will give me the most n/a power but still driven as a daily driver
thx
Old Mar 29, 2004 | 12:28 AM
oil pan 4's Avatar
I would think that if you get less than 200 hp some thing would be very wrong.
I think YOu could get as much as 240 on the ground at most (with those 1.6 rockers helping), I'm saying no more than 240.
I think you might want to get a 2.8/3.1 intake for that cam.
With my 3.4 and crane cam (216*/228*) I think I can get 220 at most no lest than 190.
Old Mar 29, 2004 | 06:20 PM
well im tryin to get the most n/a power i can right now but plan on addin turbo kit in the summer so i dont wanna do anything thtas gonna need changin then, so what cam yall guys reccomend?
Old Mar 30, 2004 | 01:40 PM
in addition to what cam i should get (something that gaves the most n/a gains) with these mods what kind of rwhp and rwtq am i lookin at before turbo and after intercooled turbo runnin about 6-7 psi? thx
Old Apr 1, 2004 | 12:10 AM
anyone got any info to help me out?
thx
Old Apr 2, 2004 | 10:01 AM
camarogeek's Avatar
The problem is that turbo cams and N/A cams are very different. You would want a completely different setup for a turbo, so if you're going to cam i'd cam with the turbo project.
Old Apr 2, 2004 | 02:58 PM
yes i understand the difference, but i want a fast n/a car right now, the turbo is a ways away, but even if i get an na cam and turbo later that will produce more power than just leaving the factory and turboing, so i just need an oopinion on a cam with the biggest n/a gains
Old Apr 2, 2004 | 03:53 PM
oil pan 4's Avatar
If you want a cam I think the lutani 228*/228* is just plain wrong for a turbo cam.
If I rember right it had 8 degrees of over lap.
I have the crane 272 cam.
216*/228* @.05''
.454''/.480'' of lift
LSA is 112
It has 1 degree of over lap.
It should make a good mid range power turbo cam, not a good choice for top hp and high rpm's.
Any way it would be a huge improvement over the stock cam n/a or turbo.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
