tranny in manual 3.4 hops. need help
Old Oct 25, 2003 | 04:17 PM
95camaro3400's Avatar
when i get on the gas in my camaro 3.4 my tranny hops up and down, i checked the mount according to the haynes manual by putting a pry bar between my crossmemeber and my tranny, i can raise my tranny about 2 inches, does this mean my tranny mount is broken? if so where do i go about buying a new one? thx
Old Oct 25, 2003 | 07:12 PM
morb|d's Avatar
yes. you can get an SLP tranny mount from slpengineering.com (i think). i don't remember for sure but you might have to drill a new hole in the crossmember because the OEM hole doesn't align.
some people go for the poly mounts but i wouldn't do it unless you're ok with your car sounding and shaking like a tractor all the time.
Old Oct 25, 2003 | 07:58 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
i have a polyurethane trans mount and my car doesnt shake like a tractor... however it does viberate more... but its kinda nice..
drilling the hole in a crossmember isnt hard at all, just take the crossmember out of the car before you do it.
Old Oct 26, 2003 | 10:46 AM
will this one fit my car.
Definitely one of the most popular Energy Components for years, these re-engineered mounts have led the industry and are in demand, both for the track and the street. Several applications utilize Energy's patented safety interlock. Impervious to under-car fluids!
Components Do Not Rot Or Deteriorate!
Dramatic Improvement In Vehicle Handling!
Two Year Warranty!
Available in Red or Black Polyurethane
Available in Chrome or Zinc finishes
Part Number
Description
Price
Buy
ES-31108
Energy Suspension Polyurethane Transmission Mount (Zinc Finish)
$24.95
Polyurethane Color
BlackRed
(ammperformance.com)
Old Oct 26, 2003 | 12:11 PM
atl2001's Avatar
im pretty durn sure that you will have to drill the crossmember, and rig up a spacer (i used an extra nut i had) for it to work properly
it took me an hour or so to do mine, but it was a prothane mount not an energy suspension
Old Oct 26, 2003 | 12:55 PM
morb|d's Avatar
might want to go with something a little more solid than an extra nut for the spacer.
for any of the poly bushings you might get you'll definitely have to drill a new hole. I'd use some kind of shim as the spacer (the poly mount is shorter than stock). washers and nuts aren't really a good idea. you can make them from a bunch of household things preferably made of steel. you only need to raise the tranny about 1/4 of an inch to get it back to the stock position with the poly bushing.
colts0455
Jul 24, 2015 04:51 PM
Anon
Jul 23, 2015 12:18 PM
67chevy
Parts Wanted
Jul 20, 2015 02:27 PM
GT what?
Jul 14, 2015 10:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
