swap 94 3.4 v6 camaro with a LT1
Old Mar 15, 2009 | 06:33 PM
turnerracing354's Avatar
I have a 1994 camaro with a bad 3.4 v6. I just got an 93 Z28 camaro that was wrecked with good motor and trans. What all will i need off this car to fix my 94 camaro. Thanks to anybody that helps
Old Mar 16, 2009 | 08:25 AM
blown94's Avatar
do a search, i think theres even a sticky thread
Old Mar 17, 2009 | 10:42 AM
chevyman19's Avatar
you will have to take the wireing harness out of the z28 even the dash harness switch it all out with yours then it should all hook up...but like blown94 said there should be a thread about it
Old Mar 18, 2009 | 02:31 AM
JooneJune's Avatar
stay within the same year it makes it a heck of a lot easier.
Old Apr 25, 2009 | 01:08 AM
custom95's Avatar
sticky at the top of the forum. It's a beeeyatch just to let you know unless you're mechanically inclined and have a good set of tools.
Old Apr 28, 2009 | 02:09 PM
shock6906's Avatar
The answer to your question is the reason I have a 3.4 Camaro and a Z-28 Camaro. By the time I looked at the work involved and the money involved in the swap, it was a better decision to just buy the Z. If you really want to do it, though, you'll need to use the K-member, complete wiring harness, and gauges from the Z-28, and I'm sure there's more that I don't know because I just haven't done it.
Old Apr 29, 2009 | 02:02 PM
JooneJune's Avatar
See my avatar, green car= 1995 3.4L, Green motor= LT1 thats currently in the green car .
It really is a PITA, but you can do it. I'm accually taking the lt1 out of the green car now and putting it in a firebird... I'm on a firebird kick now...
Old May 4, 2009 | 01:50 PM
thanks to everybody that has helped. I picked up a wrecked z28 for a $1000 and i've got the rear ends and motor switched over now im just to the odds and end so it should running soon hopefuly
Old Oct 9, 2009 | 11:38 PM
supercharged024's Avatar
You still have the 3.4 sitting around or not? Looking for a set of pistons.
Old Jan 12, 2010 | 03:07 PM
Gtlol.z28's Avatar
Ls1 over lt1
Honestly if i had a pony car camaro and wanted to do an engine swap i would just go ahead and throw an ls1 in there. The lt1's are good and all but the ls1's have the latest in materials, electronics, and engine design philosophy.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
