starting problems
Old Dec 12, 2012 | 11:32 AM
1996z28red's Avatar
starting problems
hello,
I have a 97 3.8L RS and i am having a starting issue with it. when i turn the key it dings twice for the seatbelt and then nothing. when i try to start it nothing happens. i can hear the fuel pump kick on but thats it. it wont even turn over. it has good battery power and everything. The problem started a couple months back when the car would do the same thing but after about 3 or 4 tries it would turn on. i replaced the lock cylinder but that had no effect. I just did a full rebuild on the engine and transmission a month ago and i would really like to get some use out of the car. Thanks for the help!
Old Dec 12, 2012 | 04:20 PM
parkers Z28's Avatar
Re: starting problems
Check to see if the cables or tight on the starter & battery
check to see if the starter or the starter relay has gone bad
Old Dec 17, 2012 | 11:55 PM
Jeffs1997's Avatar
does the security light stay on after key is in run position for more then 15 seconds? I would also check the neutral start switch and vats start enable relay.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
