starting hesitation?
Old May 27, 2003 | 06:04 PM
court99z28's Avatar
my girlfriends 3.8 1999 has a hestitation when the key is turned to start the car. It is trying to turn over but just seems to not get all the way for a couple of seconds what is the solution.
bad fuel filter or pump a possibility
thanks
Old May 30, 2003 | 11:56 AM
nothingeined's Avatar
Check the connections on the battery like killerjello said. Mine used to do that because the positive wire was loose from my amp install. It would start, but rough. One day it did not even turn on. Find out it was loose. Good luck!
Old May 31, 2003 | 01:58 AM
fbird95's Avatar
Make sure you let the fuel pump fully prime before you crank the key, this can buy the problem in many cases.
silvermansteve
Mar 4, 2015 05:02 PM
Bignasty85
Mar 3, 2015 04:05 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
