Rough running
Old Oct 26, 2003 | 05:55 PM
markf99's Avatar
Rough running
There's probably about 1000 answes to this, but I'll ask anyway. I have a '93 Camaro 3.4 that is running and idling very rough. Sometimes it will smooth out for a few seconds, but then it will start running rough again. Big loss of power, and gas milage. Replaced the MAP, and O2 sensor, plugs, wires, EGR, and cat converter. It acts like a vacuum leak, but I can't find one. any ideas? Thanx.
Old Oct 26, 2003 | 06:16 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
have you tried to reset the idle?
pull the PCM fuses, put them back in, then start the car and pull it into drive immedatly with the AC off, then let it idle for 5 min, turn it off, then let it sit for 10 sec, then start it and let it idle for 5 more min.. see if that helps
also how many miles do you have?
Old Oct 26, 2003 | 06:36 PM
markf99's Avatar
118,000.
Old Oct 26, 2003 | 08:38 PM
camaro6's Avatar
I've got the same problem too and i can't figure out how to fix it
Old Jan 3, 2004 | 08:14 PM
93 LT1's Avatar
Thumbs down
Guys, I got the same problem to with my 93 3.4L. It runs like a caddy on the expressway and driving, but idles like a monster truck at stop lights. Replace all of the above to. Im starting to think that it might me the exhaust. Anyone fix it or at least chase it down?
Iamherefornow
Jan 26, 2015 04:57 PM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
