Rod Bearings job
Re: Rod Bearings job
Well what engine is it for?
You will have to pull the engine out first of all.
Put the crank main cap on in the same position as you removed them same with the rods.
You should pull the heads and work on them while your at it, get new pistons maybe and at the least put new rings and hone the bores.
You will have to pull the crank out so do the main bearings too.
If you have a 2.8 3.1 or 3.4 I can tell you how to modify the main bearings so you get more oil to the rod bearings.
It goes on and on, it's a lot to do.
You will need an engine rebuild guide more or less.
It won't be simple you will need a lot of tools parts and seals.
o god this is going to be fun then
it has to be a 3.1 or 3.4
sry to ask but do you have a pic of the crank main cap
and do you kown were i can get a good rebuilt kit wth the **** i would like
i'm going to be puting a v8 in so theres no neeed to do over work
i'm geting it from here
http://www.newengineparts.com/
god its to bad i do not kown how to put in Oversize **** in.......i would like to go .040
You have to thake the engine to a machine shop and have the cylinder s bored. But you only realy need to bore them if there damage or your doing a preformance build up. If there not tore up you can just hone them and put them back to gether,
