Please Help ASAP
Old Oct 4, 2006 | 10:39 AM
DavidsZ's Avatar
Please Help ASAP
How is everyone. i have a 94 V6 i use as a daily driver. the car has over 200K miles but it has been maintained perfectly and no major problems so i hate to just get rid of it. Lately is has been having a misfire problem when it is first started in the morning, and then once it warms up and sits and idles it wil eventually die. anyone have or heard of a similiar problem. i just need a good place to start looking. does it sound more electrical or mechanical? thanks for any help
David
Old Oct 4, 2006 | 10:57 AM
GreenCamaro619's Avatar
Re: Please Help ASAP
you might want to go ahead and replace the spark plug wires if you haven't yet. Since part of the engine isn't ventilated to well, the heat gets trapped therefore heating up the spark plug wires. That will cause resistance in the wires. Hopefull this helps!!! Good luck man!!!
Old Oct 4, 2006 | 01:52 PM
2000GTP's Avatar
Is the SES light illuminated? If so, I would scan for codes. It probably wouldn't hurt to have the fuel pressure checked, make sure the plugs/wires are in good shape, and make sure the coils are all firing properly. Clogged/dirty fuel injectors can also cause engine misfires.
Old Oct 4, 2006 | 02:12 PM
GALIATHON's Avatar
[QUOTE=2000GTP]Is the SES light illuminated? If so, I would scan for codes. It probably wouldn't hurt to have the fuel pressure checked, make sure the plugs/wires are in good shape, and make sure the coils are all firing properly. Clogged/dirty fuel injectors can also cause engine misfires.[/QUOT
check your gas tank.. I had that same prob.. And it turned out I had a piece of plastic in my tank..so the car would start and idle good but once it warmed up it would do the same as yours.. So let it run and then check your fuel pressure it could be your fuel pump also.. 200k time 4 some sea foam..
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
