Please Help
Old May 13, 2004 | 09:54 PM
6shot38's Avatar
Please Help
ok i have a 1998 camaro auto trans in my cousins collision shop theres a wrecked ws6 in witch he has taken ownership of
its a 2000 m6 i waas wondering if i could do a engine swap with all th eparts from the ws6 to my camaro engine wise . i know i will need a new guage cluster but can i swap everything else it has a manual trans i know thats the hard part but i may be able to get an auto trans for it ........... I heard that i could lift the body off of it by taken aloos the k frame and some other parts then lift the car up and the engine and trans will remain
along with the front suspention im really interested in doing this so let me know anything you can
Old May 14, 2004 | 01:38 AM
99blackSS's Avatar
Depends how much it is going to cost. Is your cousin donating his time or the parts? It's not worth it unless you are getting a good deal on the parts and or labor.
Old May 14, 2004 | 07:50 AM
6shot38's Avatar
its freeee im smart enough t o do most of everything my self with some friends
Old May 14, 2004 | 09:50 AM
kahouna23's Avatar
I think I understand what you're saying.....taking the Camaro body completely off and installing it on the WS6 chassis? If that's the case.....I've never heard of anyone doing this. As for the swap from the WS6 to the Camaro...that's some pretty intense work. Wiring harness, ECU, X-member, suspension, fuel pump and lines, radiator, gauges, etc... Doing the work yourself with the help of your cousin would be the way to go. Just understand that if you have smog laws in your area, you may run into problems with the VIN# and passing the visual inspection. But, if that's not the case...........DO IT. ESPECIALLY if all the parts are FREE!!!
Old May 14, 2004 | 04:10 PM
6shot38's Avatar
yes its gonna be hard even worse
i knowim gonna need a new trans unless i can convet mine
to a m6
Old May 15, 2004 | 11:56 AM
kahouna23's Avatar
to a m6
NOT A GOOD IDEA!!!!!! not to mention $$$$$$$$
Go to the junk yard or check out this website.
www.hpsalvage.com
Old May 17, 2004 | 08:57 AM
J0HN D's Avatar
It's possible.
You really need to get your hands on a 1998 pcm and wiring harness though. The 2000 stuff will need a lot of wiring changes, where a 1998 will almost plug right in (you have to put 12v power to one additional pin). You should use a '98 gauge cluster too.
You could convert the car to a manual trans, with the addition of the clutch parts.... Since the donor car is right there, you could swap that stuff over easy enough.
Whatever transmission you go with, make sure the pcm matches it.
The tank and lines on your '98 are for a return-type fuel system. The v8 car is returnless. You can swap the tank and lines. Or you can buy a 97-98 vette fuel rail and fpr, and keep your tank and lines. The vette parts are about $210.
I'm working on a swap in a '98 myself...
Old May 17, 2004 | 01:11 PM
Triple W's Avatar
This is a good swap site also.
www.tacreationsusa.com
Old May 17, 2004 | 02:36 PM
6shot38's Avatar
Originally posted by J0HN D
It's possible.
do you thin it would be a hard thing to do swapping fuel lines
and tank
Old May 17, 2004 | 05:59 PM
kahouna23's Avatar
Well, seeing as how you'll be doing a full out swap.....with the engine, tranny, and exhaust removed the lines shouldn't be that hard to change out and install LT1 or LS1 lines. I know that the V-8's have a return line, that's why you need them. As for the fuel tank....PIECE OF CAKE!!!!
Old May 17, 2004 | 09:39 PM
J0HN D's Avatar
You should probably upgrade the fuel pump too. Most people drop the tank to get to the fuel pump. So you might as well swap the tanks while you're there... I think the 2000 tank will work, and you'll have the added benefit of it being the lighter plastic tank. You could probably get by on the v8 fuel pump, but for $120 you can get a 255lph walbro for it.
You might need to keep your sending unit though, because the output voltage range changed sometime after '98, I think it was '99. (that is, if you go with a '98 cluster....)
Gets confusing after a while huh?!
I'm keeping my tank, and going with a walbro pump, and a '98 cluster, and the vette rail. (the high hp guys prefer the return-type system over the returnless system, fuel pressure is more stable on top end.) One of these days I'll probably be putting a blower on it, so I figure staying with a return-type system makes sense for me.
