P0336
Old Mar 12, 2007 | 02:38 PM
1superchevy's Avatar
P0336
Was driving home two weeks ago (97 camaro rs auto) and felt a stumble didnt pay it any mind. Then the check engine light came on with P0336 Crankshaft Postion Sensor Performance . Had the code removed to follow the test procedures and nothing. It ran fine for a while. Now whenever it wants to it will act like its about to cut off no matter if i am moving or sitting at a light but there is no more check engine light and my gas mileage sucks . I think this ckp is still messed up i think. i check the grounds and everything and all looks ok. The last thing is crankshaft end play might be the cause. I dont know what else to look for. Any suggestions??????????
Old Mar 13, 2007 | 12:49 PM
smithtim's Avatar
How many miles do you have on the car.. I'd doubt that your problem is the actual crankshaft unless you have 10 million miles on the car... most likely that sensor is either bad or a problem with the wiring to the sensor
Old Mar 13, 2007 | 07:55 PM
Don350k's Avatar
I doubt crank slop would do it, did you check the refrence voltage? i know u said u checked grounds. tried replacing the sensor?
Old Mar 13, 2007 | 09:21 PM
I have 186,000. I was going to order a new sensor, but didn't know if i needed a new reluctor ring or who to get to re-learn without killing the pocket book. I will check the reference voltage tomorrow and post back. Thanks
Old Mar 14, 2007 | 02:54 PM
smithtim's Avatar
think it's about a twenty or thirty dollar part... so not to bad
ZX636RIDER03
Feb 19, 2013 01:39 PM
ta_ws6
Jul 14, 2009 11:48 PM
intense1997lt4
May 19, 2008 10:13 AM
intense1997lt4
May 16, 2008 04:23 PM
moparman
Jul 9, 2007 06:39 PM
