Odd vibrations....
Old Oct 26, 2003 | 11:59 PM
2nd2sex's Avatar
Odd vibrations....
Well my 97 V6 auto has been vibrating a bit around 49-50mph. Its just a slight shudder but starting to annoy me more and more. About a month ago when this started I swapped out the plugs and wires. The vibration went down a bit. Just yesterday I changed the oil, rear diff fluid, flushed the cooling system, replaced the fuel filter and had a fuel system clean (going to CA soon). The car runs a lot smoother but the slight shudder is still there at the same speed. With a little throttle or a release in the pedal the car will stop the shudder immediately. Im thinking it might be the o2 sensor but it only happens around the highway speeds. I tried a search already but most of these problems were with lt1s and the opti, some were o2 sensors. I have no codes displaying. Anyone have a clue of whats up?!? What should I do...TIA
Old Oct 27, 2003 | 12:29 AM
F1GT's Avatar
Did you try checking ur tranny mount?
Old Oct 27, 2003 | 01:07 PM
2nd2sex's Avatar
No, didnt think about that. I'll get it checked out. Is that expensive to replace?
cmsmith
Sep 14, 2015 09:25 PM
Zrout
Jun 15, 2015 05:06 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
96TAragtop
Jan 31, 2003 02:15 PM
