Need some advice from some 6'ers with Nitrous
Old 08-04-2002, 05:51 PM
2_shady's Avatar
Post Need some advice from some 6'ers with Nitrous
I was considering nitrous but have heard that it is pretty harmful to the engine.. I was wondering if its worth the $ and whats the max boost that can be run with a stock 3.8l 75? 100?
any guys with Nitrous have any probs? whats the best kit to buy? wet? dry?
also, is a 75 shot big enough to feel from the driver seat? and how many times would you spray in a race to 90-100?
will a 75 - 100 shot put down a good race with an 8?
thanks
2_shady is offline
Old 08-04-2002, 06:55 PM
ImportKILLER's Avatar
Post
Boost? Are you talking about nitrous or forced induction here?
Through a friend's friend, I was able to buy two nitrous kits dirt cheap, one for the Stealth and one for the Camaro. However, until I am 100% familiar with it, I won't be installing either. They'll be sitting in the garage.
There are a couple of sites you can visit that will help you understand nitrous. I saw a Chevy magazine this weekend with NITROUS POWER on the cover, might want to look into reading it.
I can't answer your specific questions but I don't think I would want to start spraying a stock engine. Since you CAN do major damage with nitrous, I'd suggest you do some research on the basics and then worry about if a 75 shot is enough to take down a V8.
-Nathan
1996 Camaro
3.8L Series II, SLP Cold-Air Intake, Catco cat, Accel 8mm wires, Zexel LSD, 3.42 gears and a Borla catback.
1995 Dodge Stealth R/T
Twin Turbo Intercooled 3.0L AWD M6,A'PEXi AVC-R boost control, HKS Blow-off valve, K&N FIPK, Denso Iridium plugs, 245/40/18 Kumho Supra, Borla Catback,all Mobil 1 fluids.
*VVvvTTttFFff* TNC since 1981!
ImportKILLER is offline
Old 08-05-2002, 02:32 PM
94BlackBowtie's Avatar
Red face
Since Tiago has taken a break or something, I'll let you see what he has to say...
http://web.camaross.com/bb/Forum14/HTML/012172.html
94BlackBowtie is offline
David Dempsey
03-12-2016 12:42 AM
WobblySausage
10-07-2015 02:44 PM
WobblySausage
10-07-2015 10:09 AM
68camaroboltz
10-05-2015 01:46 PM
95blkss
09-22-2015 03:18 PM
Quick Reply: Need some advice from some 6'ers with Nitrous
