Need Help Finding The Problem With My 99 Camaro
Old Mar 26, 2008 | 04:48 AM
  #16
blackmarogirl99's Avatar
Originally Posted by 95camaroinok
Sounds like hes probably right, cut the catalytic converter off, and start it up like that. It will be loud and sound like chit and it will turn your check engine light on, but you should notice it running better immediately. New aftermarket cats arent too expensive considering you've already had headgaskets replaced.
edit- just noticed your from Ca, if you cut the cat off and start it to check it, dont drive it like that so you dont get pulled over and ticketed.
Also--- Welcome to the board.
Edit again--- You should be able to just unbolt the cat, Im not sure exactly how they set it up on the 3.8, but at least that way if it is bad you can "legally" take it to have a new one put on.
My service engine soon light stays on constantly anyways and flashes when it miss fires
Old Mar 26, 2008 | 04:58 AM
  #17
2000GTP's Avatar
At that point, I would rescan the car and get the exact codes, those could be very beneficial. Especially if it is a misfire code related specifically to one or more cylinders. Otherwise, you are just going to keep throwing parts at it in hopes of correcting a problem which you may or may not accomplish.
Old Mar 27, 2008 | 06:57 PM
  #18
GETGONE's Avatar
It's probably the cat. My car started missing and losing power bigtime last week. Took it to a trans shop because I thought it was the trans slipping. He said it wasn't making enough power and that was causing the trans issue. I replaced the coil packs since he said he saw a cylinder misfire. That didn't fix it and I could hear the cat rattling. Took it to the dealer and that's the issue. I'm just under the 8 year 80K mile warranty so I'm getting it replaced for free tomorrow.
Old Apr 27, 2008 | 03:13 PM
  #19
so the cat wasnt it
So everybody said to cut the cat off well i did and its still missing like crazy we did an compression test and the left side is 200 the right is 125 ive changed all coils i think all thats left is my ignition modulator im so ready to sell this piece of crap im over it!!!!! Like ive never had a car that has given me so many problems..ugh!!!!
Old Apr 27, 2008 | 07:13 PM
  #20
2000GTP's Avatar
Could you provide the readings for all the cylinders.
Red Hawk 94
Mar 18, 2019 04:03 PM
bernie1951
Dec 10, 2014 10:03 AM
Dec 4, 2014 11:56 AM
Sarahrope64
Nov 27, 2014 11:17 AM
