in the middle of TC install, please help ASAP
Old Sep 7, 2002 | 05:49 PM
Silver00's Avatar
Post in the middle of TC install, please help ASAP
situation is that we're trying to remove the inspection plate. the two bolts that have 18 mm nuts on them are welded to the inspection plate. we got the driver side bracket off, yet the passenger side bracket seems to be lodged in there quite well. both 13 mm bolts have been removed, yet the passenger side seems to be right up there with the motor mount. It will not budge and we need advice asap...what is the next move please help if you know the answer.
Matt
Old Sep 9, 2002 | 05:56 PM
nikkev's Avatar
Lightbulb
Sorry I saw this so late.How big are the brackets?Are you sure that you got all of the bolts off?If you do then try a pair of vice grips and twist and pul to try to get it out.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old Sep 9, 2002 | 05:59 PM
Silver00's Avatar
Post
i just ended up cutting the inspection plate...blah. thanks for the reply tho
Matt
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Heathen1
Jan 2, 2016 04:27 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
ro2207
Dec 4, 2014 06:18 PM
