leaking oil pan + changing rear drum shoes....
Old Sep 15, 2004 | 03:15 PM
PitySister's Avatar
finally replaced the the drain plug as i thought that might be the problem....but after sitting there and staring at my oil pan for 5 minutes...the leak is in the pan itself....on the bottom...and while it doesn't amount to very much at all....car is never really low....i'm just disconcerted by the fact that i have a hole in my drain pan i put some stop leak in there today....see if that does it at all....but is there something i can do to the bottom of the pan to keep it from leaking....anything i can spray it with??
secondly...
anybody ever change the shoes on rear drum brakes on a 1995 f-body and have any tips???
thanks...
Old Sep 18, 2004 | 05:28 PM
PentaVolvo's Avatar
Re: leaking oil pan + changing rear drum shoes....
i did the rear drums on my 94, all i can recommend is gettin the 2 spring tool s(they r cheap), find the hanes book big help and take a picture of each side before u start. If u r in the northwest suburbs of the chicagoland area i will be willing to help you. Also replace the springs and whatnot in the drums
HectorM52
Jul 30, 2017 11:46 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
