Interesting Idea for TB
Old Jan 24, 2004 | 12:15 PM
93Cam's Avatar
Would a 3.8 upper intake fit on the 3.4. Reason i ask is that i think it would be interesting to change out the upper intake and tb from a 3.8 to a 3.4.
Old Jan 24, 2004 | 02:14 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
not at all
Old Jan 25, 2004 | 02:16 PM
oil pan 4's Avatar
If you want a better flowning intake for a 3.4 get one (an upper and lower plenum) off a 2.8 or 3.1 camaro.
Old Jan 26, 2004 | 07:22 PM
93Cam's Avatar
I just found out my mom's olds has a 94' 3.1, so is this change a mod free change or is there extensive work involved?
Old Jan 26, 2004 | 09:44 PM
atl2001's Avatar
you'll need her heads, manifolds , fuel rails and a **** load of other stuff to make that work
however if you want the best possible top end for a 3.4L you need to swith over to the 3X00 alumnium heads and manifolds, which isnt exactly something for the average "wrench turnin joe" to do
Old Jan 27, 2004 | 07:48 PM
93Cam's Avatar
Looks like the cheapest and easiest thing to do is just P&P them myself or save the headach and buy one. Thanks for the help
Old Jan 28, 2004 | 02:15 AM
oil pan 4's Avatar
If you put those heads on that camaro you will end up with a 12:1 Compression ratio.
If you have a 3X00 car to get the parts off go for it.
You will need heads, intake, fuel rail, and a few others.
To lower the C/R you will have to do a few things.
Use the 3X00 pistons
Port the combustion chamber out a lot.
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
guionM
69
Nov 30, 2006 02:01 PM
Cobraeater
10
Sep 11, 2002 02:49 PM
