Im getting a turbo 3.4 kit-need help on a few questions
Old 10-23-2003, 11:28 PM
95camaro3400's Avatar
i have a 1995 3.4l camaro . i want a turbo kit like the on Tiago has on his firebird,(turbo, piping , intercooler, bov, wastegate, fuel pump, etc)the engine itself is stock with 138,000 miles.
here goes the questions:
1.Should i rebuild before i buy the kit? if yes should i be ok with more stock internals, or are high pressure valve springs, rods, pistons necessary.(the kit will probably already take all my money so i dont want to have to buy anything i dont need)
2.What needs to be upgraded ? stage 1? 2? clutch, limited slip diff?,motor/tranny mounts? fuel injectors? oil pump?
3.What all is included in the kits available? and what are the costs of the top kits that are out there and the one you guys reccomend most?
4.will i still pass emissions with these kits?
5.should i be ok with stock cam or will an aftermarket one be necessary for big power gains?
6.Will my stock exhaust system(everything stock except flowmaster cat back)work with the kit or will i need new headers?
7.How hard are the kits to install?, i am pretty mechanically inclined and should be able to figure it out but any opinions welcome
Sorry about so many questions, but i am very serious about buying a turbo kit, it is a large investment and i want it to work right, i would like to purchase all necessary parts within the next few weeks and need everyones help on this topic.Everyones responses to this topic will be greatly appreciated.
thx
95camaro3400 is offline
Old 10-24-2003, 12:42 AM
94ZRiCeKiLr's Avatar
i dont think i would boost a 138K mile motor but if u wanna do it i think i can answer 4, 6 and 7 for ya.
4) u SHOULD theoretically be able to pass emissions no problem because a turbo uses exhaust gas to move the impellers. If anything ur emissions should be lower.
6) Turbo set-ups use custom headers to scavenge exhaust from the motor and fire it back through the turbo. no stock manifolds here.
7) u may be able to put it in urself but all the people who i know with turbo motors talk about how tempermental they are. u might want to let a pro tune that thing for u to get it to run right.
94ZRiCeKiLr is offline
Old 10-24-2003, 03:01 AM
atl2001's Avatar
Location: carbondale IL \ Alton IL (outside St Louie MO)
go to camarov6.com , and do a search..
BTW, the kit isnt out... your gonna have to wait a lil while before it is realeased
atl2001 is offline
Old 10-24-2003, 07:36 AM
Tiago's Avatar
humm, the kit IS out, it was released a while back Ive been taking orders
Tiago is offline
Old 10-24-2003, 07:47 AM
Tiago's Avatar
Re: Im getting a turbo 3.4 kit-need help on a few questions
no I wouldn't rebuild until you ran into problems later down the road. I know a guy that runs 10 lbs of boost on a stock 185,000 mile 3.4 not intercooled. Don't sweat on the miles. Run it until you blow it, then upgrade
a stage 2 or stage 3 spec clutch would be fine. I know for a fact the stock one wont like it for very long. It may last a couple months.
Don't worry about motor mounts, or tranny unless u break it, then get a poly mount.
IF you don't plan on going big boost, don't worry about injectors.
Don't touch the oil pump.
I assume you mean motor rebuild kits? I think for about $2000-$2500 in parts and $1000 in labor if you need it and you can have a bullet proof 3.4L that will take lots of boost for a long time.
yes, answered above, it should reduce your emissions.
I still use the stock cam, don't change it until you rebuild, changing cams on a higher mileage 3.4 always results in rebuilds because the cam bearigns are ****.
You dont need to have headers, you can just modify the y pipe to fit the Manifolds if you desire, but I do recommend the RK Sport headers, that is what I run on my car, and what I built the kit with.
easy
Tiago is offline
Old 10-24-2003, 12:13 PM
atl2001's Avatar
i thought only the 3.8 kit was out, my bad
atl2001 is offline
Old 10-24-2003, 12:37 PM
MustangEater82's Avatar
You don't need limted slip but honestly I think its shodul be the first mod on v6 f-bodies, makes driving alot more fun
Also did you just say you have a stock catback with a flowmaster muffler?
I woudl look into getting an I-pipe, check the local sectiosn for a used lt1 I-pipe, I got an entire stock z28 catback free, just had to pick it up. Its a 2.75 in. I-pipe, just had the exahsut shot fab up a better S-pipe, to hook it up and all was well, only cost liek $90 for the install of Catback, CAT, cutout, and a custom S-pipe with 2 45 degree angel bends instead of 2 90 degree angle bends.
Also I would serioulsy look into a differnet drivesahft get a used lt1 driveshaft is abotu $25, and a lighter ls1 drivesahft is about $100-150.
Both are lighter and stronger then your stock one, and both bolt right in.
MustangEater82 is offline
Old 09-14-2004, 08:12 AM
slickrock55's Avatar
Sorry, ive got to chime in here. Turbo's in NO WAY will lower emissions. At all.
No suprises here. If you pull the wastegate actuator rod(s) and aren't making any boost, you will be close to stock emissions, but there are still pumping losses through the turbine and the whole system will act as a restriction.
Turbo power is not free. Contrary to what you may have read/been told, it takes energy on the exhaust stroke to force the combustion gases out into the manifolds. This is what is considered "pumping losses" and comes from an exhaust backpressure of roughly 1.5-2x boost pressure.
This is actually a net LOSS in efficiency. You will burn more fuel per hp created. Keep in mind when you are cramming in all that extra air, it goes hand in hand with extra fuel. This is why the BSFC (brake specific fuel consumption) is around .6 for turbo cars, and .5 for NA. BSFC is literally the weight of fuel required to make 1 hp for 1 hr.
Will you still pass emissions with a turbo? With a working cat and no boost (wastegates unhooked), the answer is probably. You should be running close to NA power levels and emissions levels.
slickrock55 is offline
Old 09-14-2004, 08:16 AM
Doh! did a search and didnt see this thread was almost a year old. sorry all!
Old 09-14-2004, 08:21 AM
Nothing wrong with it, alot of us are still around, besides I like old threads I still had a 3.4L when I posted in this last well sort of had a 3.4L
Old 09-14-2004, 12:07 PM
atl2001's Avatar
LOL, yeah this is old , crap have thoes people that tiago was taking orders from even gotten their **** yet
atl2001 is offline
LeftoverChinese
01-14-2024 03:03 PM
RUENUF
03-13-2016 03:39 PM
DirtyDaveW
03-15-2015 07:01 PM
Newgmman
02-25-2015 02:53 PM
blac94Z
01-22-2015 11:19 PM
Quick Reply: Im getting a turbo 3.4 kit-need help on a few questions
