i need help finding whats wrong
Old Sep 21, 2003 | 04:03 PM
TylerP's Avatar
Angry i need help finding whats wrong
I am TYLER over at Camarov6.com
i figured there are also a lot of people over here who know quite a bit as well..
well basically i have this crazy misfire situation that cannot be solved what-so-ever. I've replaced..... Coil packs, Injectors, Spark Plugs, plug wires, fuel filter, air filter.
i get a continuous misfire when above 3500 rpms.. and when i get it scanned at autozone, it does not say which cylinder is misfireing. its a PO300 Code.. so it could seriously be ANYTHING that can cause misfires like that.. its like a list of 30 different things.
anyways. the problem was fixed after months of work on my car. what i did was sanded the connections on my Ignition Control Module and cleaned them off with rubbing alcohol, and the misfires went away... however, 2 and a half weeks later its back and even worse than before. so i did the same thing i did last time and still no fix.
here is a link i posted over at Camarov6.com
http://community.webshots.com/photo/...91239966ZNXaMN
once again. My name is Tyler on that board.
please help, it would be greatly appreciated.
-Tyler
Old Sep 21, 2003 | 08:23 PM
DomesticViolence's Avatar
Re: i need help finding whats wrong
sounds like your ignition is bad.
Old Sep 21, 2003 | 08:26 PM
94m5's Avatar
Have you checked your fuel pressure? If its happening above 3500, and not below, you may not be getting enough fuel. Just a thought
Old Sep 21, 2003 | 08:36 PM
TylerP's Avatar
even at idle i get a blinking code.. continuous misfire
Old Sep 21, 2003 | 08:55 PM
94m5's Avatar
As much as I hate the company, I would recomend that you take the control module out to autozone and have them test it. What engine do you have? If you have the 3800, I would also check the cam and crank position sensors, Ignition coils, and plug wires. I understand that you have replaced them, but you'd be suprised how many bad parts you can get off of the self.
Old Sep 22, 2003 | 11:59 PM
TylerP's Avatar
problem has been fixed.
all i did was add Seafoam to the oil and through the brake booster vacuum.
10 min later after smoke cleared up.. drove it around and no more SES light, no more misfire, and a lot more spinn'n tires
HectorM52
Jun 23, 2016 08:42 PM
guest74777
Mar 25, 2015 10:30 AM
mattstrike
Mar 11, 2015 07:33 PM
Sarahrope64
Nov 27, 2014 11:17 AM
floorpedal1
Sep 10, 2002 06:09 PM
