hvac
Old Dec 20, 2006 | 04:49 PM
mastorfreak's Avatar
hvac
my hvac is stuck on the floor setting. i have changed the hvac pannel but still doesnt work. everything else works i just cant change the mode control to change setting. any suggestions would be great.
Old Dec 22, 2006 | 01:44 PM
94-TAGT's Avatar
As you probably know since you replaced the controls its vacuumed controlled. It gets stuck on a certain setting when the vacuum line has a leak. There is a threeway vacuum connector that is in the engine bay to the right of where the two a/c lines go through the firewall. Either the connector is broken or one of the lines around there might have rotted so check all of the vacuum connections in that area.
Old Dec 22, 2006 | 07:40 PM
you were right. i opened the hood and right there was the broken check valve hidden behind some wires. thanx a lot. i had started to take apart the entire dash to see if the accuator valves had gone bad.
cmsmith
Sep 14, 2015 09:25 PM
trax
Oct 5, 2004 10:52 PM
c0rey
Dec 22, 2003 03:44 PM
95droptopZ
Apr 26, 2003 10:13 AM
ReznorZ28
Aug 28, 2002 10:02 AM
