Horn doesn't work
Old Jan 3, 2004 | 06:33 PM
Pabz2k1's Avatar
Question Horn doesn't work
When I press the horn I only hear a clickin noise by the relay and no noise from the horn itself. What could the problem be? Also when the stock panic alarm I can only hear the same clickin noise by the relay.
Old Jan 3, 2004 | 06:49 PM
99blackSS's Avatar
Check the fuse.
Old Jan 4, 2004 | 02:00 AM
Pabz2k1's Avatar
Unhappy
Check the fuse and it still doesn't work....
Old Jan 4, 2004 | 03:09 AM
99blackSS's Avatar
The only other thing I would know how to do is check to see if the horn is connected to the wires and then check those wires to see if they are getting power. The horn is located towards the front of the car on the passenger side, it's in front of the battery but sits lower then the battery (assuming you have a fourth gen). Then I'd check to see if it's connected (the horn has a female end that the wires snap onto). If it is hooked you can unhook it to check if it has power going to it.
If it doesn't have power then it's an electrical problem which I don't know what to do other then check the fuse and you already know it's not the fuse (prey this isn't the case).
If it does have power it's the actual horn, which you will now know how to install.
Old Jan 4, 2004 | 04:09 AM
kevin 2.8's Avatar
my car had dual horn option and i got the same clicking noise one day. i just unplugged one of the horns and it worked again. a little bit wimpier sounding as the deep horn was the one that blew... oh well
Old Jan 4, 2004 | 04:14 AM
99blackSS's Avatar
Yeah, technically theres two horns and they are wired together.
Old Jan 9, 2004 | 12:31 AM
scott9050's Avatar
You have a short in the horn that is causing the clicking noise. If you could see the relay in the dark you would see electricity popping brightly inside because of the short causing the noise. A replacement horn should cure the problem.
Old Jan 9, 2004 | 08:38 AM
Pabz2k1's Avatar
I replaced\ the horn and it's still makin the clickin noise....
Old Jan 9, 2004 | 01:06 PM
kevin 2.8's Avatar
http://www.camaro.org.uk/wiring.html
wiring diagram
Old Jan 12, 2004 | 01:39 PM
Pabz2k1's Avatar
hmmm? i can't find the other horn.....
Old Jan 12, 2004 | 02:03 PM
kevin 2.8's Avatar
the horns should be attached, your car must not have come with 2.
if the horn is new then there is a short somewhere. try changing the accessories fuse
or scan the wiring diagram and look for shorts
Old Jan 14, 2004 | 01:27 AM
HBHRacing's Avatar
just because the relay is clicking doesn;t mean it;s working.. they system is usaualy... 2 hots in.. ground from the horn switch to trigger the relay and send hot out.. see what you have....
Old Jan 14, 2004 | 11:43 AM
Pabz2k1's Avatar
huh? Don't understand what you said.....
Old Jan 14, 2004 | 12:55 PM
HBHRacing's Avatar
Sorry.. try this... they relay should have 4 wires going to it.. with the key on and engine off or running you should have 2 postive voltage wires... then when you press the horn switch you should have a ground signal on tanother wire (usualy black) then on the last wire with the horn button pressed you should have another hot.. that hot goes out to the horns to activate it.. what you can also do is check for hot and ground at the horns themselfs.. if it;s a one wire at the horn then it should be hot when you press the button and it gets it;s ground from where it bolts to the body or frame ect..
rideordie
Nov 5, 2019 04:52 PM
eazyZ
Mar 1, 2015 07:12 AM
fpete1992
Dec 11, 2014 03:51 PM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
