engine swap
Old Apr 11, 2004 | 08:00 PM
eneal13's Avatar
engine swap
does anyone know if the wiring harness from my 3.4l v6 will work if i drop an LS1 in to my car?
if you have done an engine swap, how much did it all cost you?
Old Apr 11, 2004 | 08:11 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
the harness will not work, you are going from an OBD I car to an OBDII motor
Old Apr 12, 2004 | 04:44 AM
oil pan 4's Avatar
Lightbulb
Those 2 engines share no parts.
Other stuff you have to change trans, trans clutch lines, engine mounts, struts springs, trans mounts fuel lines, radiator, exhaust.
There is no way a V6 harnes is going to run a V8.
It will cost a lot a few thousand.
You could check out what I got for my v6 for about $1400, should kill plenty of V8s.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
