electrical problem
Old Sep 5, 2010 | 02:08 AM
Garcia95's Avatar
electrical problem
i have a problem with my 95 camaro the car was starting and was left alone for a while now it wont start and when i connect the charger to the battery i notice the lights turn on and after a while i try to start it and nothing happens all the inside light go off and will not start. There is an electrical problem but i have not been able to see it. Has someone had a similar problem let me know if you all had a solution.
Old Sep 18, 2010 | 06:59 PM
95camaroinok's Avatar
battery cables
Old Sep 18, 2010 | 07:46 PM
razor02097's Avatar
I was having issues with my Z.
I ended up spending 10 bucks at the local auto parts store... picked up 2 new side post terminals, battery corrosion cleaner, brush and battery terminal protect spray.
clean the heck out of the cable ends and replace the terminals... then spray the battery anti corrosion stuff on. It made a world of difference for mine.
Old Sep 19, 2010 | 01:14 AM
Actually... to extend on that some.... If your still rockin the factory type cables, cut the rubber off the end of the cable ends at the battery. where the entire ring is exposed and then clean it off good. I bought my Z28 from a shop with a "locked up motor" and ended up getting it started right up from cutting the rubber off and cleaning. Just cut around the base of the "end" to where you'll expose that ring. Then use some kind of battery terminal silicone to seal it off.
Old Sep 25, 2010 | 01:21 PM
Garcia95's Avatar
thanks guys never tough of that ill do that asap
Old Nov 2, 2010 | 01:21 PM
LT1 Dreamer's Avatar
Re: electrical problem
I also have a 95 3.8l camaro with a problem similiar i put in a new engine. and put the wire harness the best way i can i think i might need some photos of a another 3.8l to get a visual if i did it correctly or i diagram anything would help. but my issue is that i can get the engine to turnover anymore it did it like 6 times but i had to stop trying to start it because my fuel line began to leak. i just bought a new starter and i hear it in motion as i turn the engine in the on position. any feed back would be greatly appreciated.
Old May 7, 2011 | 03:39 PM
Garcia95's Avatar
problem solved it turned out to be two ground wires that were busted and now the lights are working properly.
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
