Changing gears..
Old Nov 21, 2002 | 03:40 AM
k9ulan's Avatar
Changing gears..
Looking art changing the gears in my (wifes) 96, What do I neet to know..?..carrier size?...existing size..it it had drim brakes..anybody have any opinions..?
Old Nov 21, 2002 | 01:43 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
what gear does it have now , and what are you wanting to go to? It might be be in your best interest to just get a used rearend from a Z and transplant it. thats what im planning on doing
Old Nov 23, 2002 | 05:15 AM
1fastV6's Avatar
call these guys http://gearsareus.com thats what i did
but your right, you will need to know what series she has right now.
Old Nov 23, 2002 | 12:19 PM
blue95's Avatar
auto v6 is normally 3.08's
manual is normally 3.23's
If you still aren't sure look for these codes in your glove box or door
GU80 = posi
GU2 = 2.73(only V8s)
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42(came with Y87 option)
2.73, 3.08 are a series 2 carrier 3.23 all the way up are a series 3. If you do changed the gears then get the posi if you don't already have it! Or if you have drum look for a rear from a Z car and you can get a 3.42 gear, disk breaks and posi that have been factory set. I think most M6 cars came with 3.42's...but correct me if I am wrong
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
