car starts....sometimes
I just started having this problem, where my Camaro doesn't want to start. I have full power to everything, radio, lights, horn, blah blah blah. But when I go to crank, I hear nothing, except the fuel pump engaging. Sometimes I can play with the battery connection while someone is trying to start it until I can hear the starting trying to grab, but I haven't even gotten that. I have checked all the connections and everything is connected like it should be.......I get frustrated and leave the car sitting for a few hours, come back and the car starts right up. I am extremely baffled, please help me figure this out.
Re: car starts....sometimes
I bad a similar problem with my 97 3.8 turns out it was something on the steering column was burnt. Im sorry I don't know the name of the part but when the key is turned it pushes a metal down the Column into this device.
Sometimes the side-post connections on GM batteries go bad. Make sure your cables are connected connected tightly, and try a different battery. A continuity tester will often not show the problem, since there's enough connection for that little trickle of current, but not enough to turn a starter.
Do you by any chance at all remember what it was called?
The key cylinder is connected to the ignition switch by a rod... sounds like what he is describing.
4th Gen F-body Ignition Switch Replacement
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
