Burning out
Old Oct 16, 2003 | 11:11 PM
3.8LCamaro98's Avatar
Burning out
Well my friend has a 99 z28 and when me and my friends are burning out he usually just sits there and watch. We usually do it when its wet out so it doesnt damage anything but he thinks is still will even if its wet outside. So i just wanted to know is it true. I mean will it damage anything EXP: like tranny, engine, etc... I just wanted to know because if it does then i need to not burn out as much. Thanks
Old Oct 16, 2003 | 11:41 PM
99blackSS's Avatar
If your doing a neutral drop or brake stance to peel out then yes it doesn't really matter if it's wet or not, it's still pretty bad for the car. Neutral drop is real bad. If you just flooring it then I wouldn't think it would cause anything to break, especially if the tires aren't very sticky.
Old Oct 16, 2003 | 11:52 PM
I do a lot of stand still burn out. When i just mesh on the brake and the gas at the same time and spin the tires. So i guess that not very good i guess ill easy up a little on burning out then. Thanks for the replie. BTW what/could be damaged if i do stand stills.
Old Oct 16, 2003 | 11:56 PM
Knowklew's Avatar
Its hard on the brakes....and the tranny mainly.
The excess heat can warp the rotors and the tranny just takes a beating
Old Oct 17, 2003 | 12:38 AM
camaro6's Avatar
As long as you don't do it for too long it shouldn't hurt anything. After a while, it could hurt your breaks and tranny.
Old Oct 17, 2003 | 12:48 AM
97BBlackZ's Avatar
I think the question is why are you doing burn outs so much.. hehe
Might want to save up for some new tires at the rate your going
Old Oct 17, 2003 | 12:50 AM
camaro6's Avatar
lol good point
Old Oct 17, 2003 | 01:22 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
when i got my car with 84K on it i did a lot of burnouts.. probably too many
but dont worry my car is still kickin it with 120K on it now :knocks on wood:
the rear brakes are shot (mainly due to being so old).. but the trans is still fine
Old Oct 17, 2003 | 12:58 PM
MustangEater82's Avatar
Just do not jump the gas, sudden jolts to the drivetrain are bad.
You are killing your brakes, and still being pretty rough on your tranny. In the end its not the greatest thing to do, I mean its just burning out. If you are going to do something to beat the drivetain, powerslide the car... or do you have an auto.
Old Oct 18, 2003 | 01:24 AM
94ZRiCeKiLr's Avatar
just do some donuts or something...powerbraking is really bad on stuff especially if u leave it in D or OD and sit there long enough to start shifting in the burnout....at the track i USED TO burnout all the way into 3rd...then i blew up a rear...
Old Oct 18, 2003 | 02:03 AM
97QuasarBlue3.8's Avatar
Here's what happens when you do burnouts
1) Brake stands--you heat up the tranny and the brakes. Plus you're putting a lot of strain on the engine, and you're shredding your tires (less if it's wet out)
2) Donuts - tires, steering, engine, and suspension components. It wears the tires, puts strain on the engine, and with all that steering you're likely to heat up the PS pump a lot...and you're putting a lot of stress on the steering arms, joints, hubs, bearings... Also not so good for the transmission since you're probably giving it some good jolts
3) Flooring from a stop -- sudden jolts to the driveline as stated above are not good. Lots of stress on the rear gears. Will eat the tranny if you shift from N to D or 3 while spinning high RPM's.
Plus it's a waste of gas, and not worth being noticed.
(okay maybe I'm sounding pessimistic. Well, that's because I had to buy new tires for my car not too long ago and it emptied my wallet)
Old Oct 18, 2003 | 03:44 PM
97BBlackZ's Avatar
but then again whats the fun point in having our cars
Old Oct 18, 2003 | 05:42 PM
OutKlast's Avatar
I get free tires for as long as I own my car... But I've never done a burnout, I might do it once. I'd never do it on a regular basis.
HectorM52
Jun 23, 2016 08:42 PM
blac94Z
Apr 22, 2015 04:53 PM
sideways_Into_3rd
Sep 17, 2002 11:04 PM
Achilles97
Sep 16, 2002 12:27 PM
Beast87GTA
3rd Gen / L98 Engine Tech
Sep 4, 2002 12:26 PM
