Alarm trouble...Help
Old May 9, 2007 | 11:35 AM
2lucke4u's Avatar
Ok this is the problem.When I lock my doors and start to walk away the alarm goes off.Then I hit the lock button and it stops and works like it should.I have a 1998 V6 RS.Anyone know anything about this?It's driving me crazy!
Thanks in advance.
Scott
Old May 16, 2007 | 07:12 PM
2lucke4u's Avatar
ttt
ttt
Old May 16, 2007 | 11:18 PM
Don350k's Avatar
Stock alarm? Aftermarket?
in bolth cases turn the sensitivity down is where id start
Don
Old May 17, 2007 | 08:10 AM
2lucke4u's Avatar
Stock system.How would I turn the sensitivity down?Thanks
Old May 17, 2007 | 12:31 PM
2001NBMZ28's Avatar
There's a small white sensitivity **** on the shock sensor in the spare tire area - it doesn't turn much, but counterclockwise turns it down. If that doesn't work try unplugging the sensor and see if it goes away - if it does the sensor is probably bad, check to see if water somehow got to it also.
Heathen1
Jan 2, 2016 04:27 PM
IndyZman
Oct 22, 2015 02:17 PM
MichiganSkip
Aug 6, 2015 09:38 AM
OutlawPerforman
Jun 15, 2015 12:49 AM
