99 V6 needs gears what should it get?
Old Jul 29, 2002 | 04:47 PM
30thANNIVZ-28's Avatar
Post 99 V6 needs gears what should it get?
A friend of mine has a 99 V6 automatic that he wants to put gears in. It has 3.23s in it and he wants more. Should he go with 3.42's or step up to 3.73s? This car is in Miami so it needs to be daily driveable and the car is always on the highway doing at around 80 so gas mileage is another issue. If any of you have these gears could you please tell me what RPMs he would be at around 80? Any help would be awesome! Thanks
97 Z-28 30th ANNIV. EDITION(white w/ orange stripes),T-TOPS,A4 3.23 REAR MODS= MTI COLD AIR INDUCTION,FLOWMASTER,3in CUT-OUT, MAF DESCREENED,SLP AIR FOIL,TB BYPASS,160stat,LT-4KM,EDELBROCK HEADERS W/ GUTTED CATS,02 SIMMS,RK SPORT 8MM WIRES,NGK TR-6's,N20 WORKS 150 SHOT W/REMOTE OPENER,AUTOMETER GUAGES,20% TINT,BMR STB(Orange),SFC'S AND ADJ. PANHARD BAR(orange)32mm & 21mm 1le sway bars,NEON UNDERBODY KIT(ORANGE) WHITE SS RIMS 17X9.5 F & 17X11R
PLATE= H8 2LUZ
To be installed SS hood, 3.73s
Old Jul 29, 2002 | 05:39 PM
shortdog273's Avatar
Post
Go with the 3.42s. If he does alot of street/dragracing, then get 3.73s
Old Jul 30, 2002 | 06:12 PM
mdchaser's Avatar
Post
I just went from 3.23s to 3.42s. Definately go with the 3.73s. And make sure to get an lsd unit at the same time (only $99 from rksport) along with the additive.
Jeff R.
http://camaro.rscpro.com
97 RED RS, intake, exhaust, suspension, and sound.
Old Aug 2, 2002 | 07:42 AM
ravenp's Avatar
Post
Just an opinion, but gear changes are not easy or cheap... if he needs the car as a daily driver, 3.73's are too high. The jump from 3.23 to 3.42 isnt' that significant. I would spend the money on something else.
Does he have a high stall converter? 2800 or 3000 rpm, 9.5". That will boost the rearend, what about one piece aluminum driveshaft?
If he were at 3.08's, i'd be all over suggesting 3.42's, but it's not as significant a difference when you've already got 3.23's.
Good luck...
1997 silver Camaro RS
SLP CAI, 2 1/2" dual Ravin! exhaust, b&m shift improver, SLP air temp mod, 180 thermo.
http://members.rogers.com/ravenp
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
