98 runs then wont start
Old Jul 27, 2011 | 12:15 AM
  #16
CCLAN64's Avatar
Re: 98 runs then wont start
It basically acts like I ran out of gas.Everything seems to be in working order except the car will not fire up.Furl pressure was a steady 50 lbs at running idle on a cold engine.As I write this the car ran fine earlier but it may not start tomorrow.Has anybody had a fuel pump act like this??
Ace1252 I thank you again for that trouble shooting guide !!
Any more ideas ???
Old Aug 10, 2011 | 02:28 PM
  #17
CCLAN64's Avatar
Nope it does not seem to be a security issue
Old Oct 3, 2011 | 01:41 PM
  #18
Tokuzumi's Avatar
Is your car a manual or automatic? I can't really tell by your OP if the engine turns over, or not when you are having this issue. I noticed in my formula (6-speed), that if I don't have the clutch pushed in all the way, my car won't crank. It won't turn over, or do anything, but make some noises under the dash. As soon as I push the pedal in all the way, it fires right up.
Old Jan 17, 2013 | 03:19 PM
  #19
cargotec's Avatar
i had one with the same problem, never figured it out but, try, turning the key on and wait for fuel pump to stop working, then do it 2 more times and see if sne starts
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jessie4tin
Jan 7, 2015 08:53 AM
