95 camaro new motor problems
Old Jun 27, 2011 | 07:36 PM
busscher25's Avatar
Hey guys, just joined the forum, really need some help, i have a 95 camaro 3.4l, the motor ran just till the day we pulled it out to swap it with a used 3.4 motor the exact same motor, after we got it all together, we tried starting it and it just trys to turn over, there is fuel in all the lines its just not getting to the injectors any ideas?
Old Jun 28, 2011 | 01:39 PM
transamtom's Avatar
Re: 95 camaro new motor problems
Have you checked your fuel pressure?
Old Jun 28, 2011 | 03:46 PM
busscher25's Avatar
Yea, we have fuel pressure all the way up until the injectors....push that valve and fuel comes out
Old Jul 1, 2011 | 10:24 AM
transamtom's Avatar
What is the pressure reading?
Old Jul 11, 2011 | 08:58 PM
Need4Camaro's Avatar
Agreed, just cuzz fuel squirts out doesn't mean there's enough pressure to run an engine. I was having problems with my 3.8 V6 not cranking and did the same thing, fuel came out, but after a pressure gauge was used it was found to be nowere near enough fuel to run the motor... It was only at 15 PSI and while it looked plenty to the eye, it wasnt anywere near what was required to crank the engine... It requires 60 PSI to run... ...turned out I had a bad fuel pump.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
NewsBot
Dec 28, 2014 06:20 PM
ChrisFrez
Dec 7, 2014 11:32 AM
ChrisFrez
Nov 23, 2014 10:33 AM
1LEThumper
Jul 14, 2003 12:45 PM
