95 3.4 V6 Camaro Engine Swap to Gen 1 327.
Hello im new here i was wondering if any one could tell me where to get this part i need.1st off i have a 95 camaro that had a 3.4 in it so i bought a 69 impala and put the 327 trans and engine in the camaro but the only problem im running into is the motor mounts the engine fits but is not mounted yet so i need to find shorter bracktes that bolts up to the block of the engine to the mount on the frame thanks for any help....
Your V6 K-member (engine cradle) is totally different than the V8 K-member. You need a V8 K-member to support an SBC.
And since neither what you started with, and what you swapped in is an LT1 engine, not sure why this is posted here. I'll move it to the "V6 Tech" forum, where this type of engine swap is covered.
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Jul 4, 2005 05:00 PM
