94 camaro v6 water pump replacement
Old 10-13-2007, 01:00 PM
stevesport47's Avatar
Unhappy 94 camaro v6 water pump replacement
I'm trying to replace a water pump on a 94 v6 3.4L and I seem to have run into a problem with removing the power steering pump bracket. I've pulled 2 bolts but there is a 3rd one behind the electronic distributor assembly. Does anyone have any tricks on getting the pump out without pulling this bracket? Any tips on getting the bracket off? Any help would be most appreciated. Either reply to this thread or send me an email. stevesport@verizon.net
stevesport47 is offline
Old 10-13-2007, 07:34 PM
FunkZ's Avatar
You have to pull all 3 coil packs and the ICM bracket to get to those bolts. There's another 2 bolts or so down on the side of the block.
FunkZ is offline
Old 10-16-2007, 07:46 AM
black95maro's Avatar
yea you need to pull the packs and the ps pump. go check out auto zones website they have a guide with pics for just about everything. pretty nifty
black95maro is offline
Jazsun
12-29-2014 12:14 PM
Queens94z28
12-20-2014 09:11 PM
pologreen97z
12-02-2014 10:42 AM
cristian1311
11-23-2014 02:22 PM
Quick Reply: 94 camaro v6 water pump replacement
