4th gen engine issue
Old Aug 24, 2011 | 07:43 AM
Nate LeDuc's Avatar
Question 4th gen engine issue
I'm not really sure how to word the title so I kept it generic. When I'm in first gear and starting is feels like for a second I'll drop down to three cylinders, then jump back up to 6 (l32 motor) I've changed my cam, crank, and oxygen sensors, New ICU and a bunch of other parts replace. I'f I try to rev it, it doesn't rev for a second. Usually this happens for only a second then my motor runs normally.
Afterthoughts?
Old Aug 24, 2011 | 05:05 PM
Re: 4th gen engine issue
The L32 would indicate the 3.4L V6 used from 93-95. You might want to post this in the "V6 Tech" forum.
You should also add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That info helps others help you
Old Aug 24, 2011 | 11:05 PM
Nate LeDuc's Avatar
After owning my Camaro for a year, I finally was able to fix my fuel sending unit, thus showing my current fuel level. I replaced the entire assembly with one from a 5.7 ( rebuilding an LT1 currently) and the problem seamed to go away, knock on wood. I think it may have been my fuel pump not being able to push supply a constant needed psi. This is just my theory. My new pump hasn't had any problems.
Roadie
Feb 16, 2015 10:34 AM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
