3800 Question
Old Nov 19, 2002 | 11:42 PM
Evil Turbo SS's Avatar
3800 Question
Is the 3800 in the late 4th gen a 60 deg V6 or 90 deg V8. Will a GN motor "bolt in" to the place of a 3.4 or 3800????
Old Nov 20, 2002 | 01:37 AM
stars1010's Avatar
Re: 3800 Question
Well I know the 3.4L is a 60 degree, not so sure on the 3.8L, I want to say its a 90 degree but I’m not 100% sure.
About the GN bolt in, well from what I’ve heard it doesn’t quite "bolt in" But it does fit. I hear all you really need is custom motor mounts and your good to go.
There is someone on the board (I cant remember his name) that pulled out his LT1 and dropped in a GN. Don’t ask why. But he’s around and he's got some pics of the project.
Old Nov 20, 2002 | 02:09 AM
MustangEater82's Avatar
3800 series II is a 90 degree motor that does not have interchangeable parts wiht the 4.3L
a GN motor will not bolt up but it can be done, like said I jsut think custom motor mounts, as for the tranny, not sure if it will bolt up right, may just want to go with a th700R4 or a Th350 anyways.
Old Nov 20, 2002 | 03:03 AM
So the 3800 is a series II 90 deg. motor. So, will the Camaros with the 3.4 60 degree motor be able to use the same motor mounts if you swapped in the 3.8 60 deg. GN motor? Is the buick 60 deg. motor in the same "family" of engines as the 60 deg 3.4?
Old Nov 20, 2002 | 03:16 AM
from what I understand nope.
Old Nov 20, 2002 | 11:04 AM
stars1010's Avatar
The 3.4L family can be traced back to the 2.8L v6's found in third gens. The GN motor mounts have to be fabricated for f-bodies. But that shouldent be that hard.
Noenav
Mar 1, 2019 07:38 AM
mattstrike
Mar 24, 2015 02:11 PM
mattstrike
Mar 12, 2015 10:12 PM
camy 1993
Feb 1, 2015 07:16 PM
bossco
Nov 29, 2014 10:18 AM
