3.4 w/ NOS
Old Aug 17, 2002 | 07:58 PM
BradC's Avatar
Post 3.4 w/ NOS
Anybody done this? Does it work OK? Will a 100 shot damage the engine or is it OK?
Old Aug 17, 2002 | 09:36 PM
camaroKID's Avatar
Post
100 shot is alittle much for a stock 3.4L. i had nitrous on my other car(now collecting dust in my garage). i would run a 50 shot if you are going use it alot, the most i would ever run on a stock bottem end 3.4 is 75 shot,and that is if you want to keep the engine for any long amount of time. if you want to granade you motor then go for the all out 150 shot !
chris - got to keep the maro!
-94 3.4L A4 camaro, 15.84 @ 87,
-other car- 1973 plymouth satellite,built 360.
-brand new old car- 1978 L82 corvette, slightly modded
-Plymouth site
-general pics of my life
-camaro site
Old Aug 17, 2002 | 09:39 PM
nikkev's Avatar
Exclamation
Nitrous is very tricky.It will find any weak spot in your motor and break it.If you are sure the engine is tip-top then nitrous will be fine as long as you use if correctly.Read up as much as you can and visit the nitrous forums.The more you know the better you are.Nitrous with enough fuel = OK.Nitrous without enough fuel = BOOM.So you have to take into account your fuel pump,injectors,etc.Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
cardemo16
Aug 24, 2015 01:04 AM
colts0455
Jul 20, 2015 09:52 AM
