1995 3.4 v6 options....
Old Aug 4, 2002 | 03:45 AM
PitySister's Avatar
Post 1995 3.4 v6 options....
i've done some searching on here..but i've still got some questions....
i've got the K and N fipk generation II kit on my car...and i'm looking to add a new exhaust...and don't know if the magnaflow catback is worth the $400 extra rather than just have a magnaflow muffler installed? is there really that big of a difference...
i was looking at jetchip's and wondering if after i upgrade the exhaust...and get the stage 2 chip....how much would it actually do for me, and is it worth the money...
right now i'm so bummed out on getting the 3.4, i just want to get a new muffler and a shift kit, cuz it's kinda sluggish going into 3 and 4...and save my money for something else....like paying off the car
i won't be doing any racing....i just want some boost....any and all opinions are welcome....thanks...and great forum by the way!!!
www.edesignaudio.com
Old Aug 4, 2002 | 12:49 PM
MustangEater82's Avatar
Post
I wouldn't worry about the chip form what I heard its no much of a gain, and its pretty freaking expensive.
I need have a stock z28 catback, sitting in my room waitng to be installed. The i-pipe has a half in. bigger I-pipe, and a I may or may not keep the muffler depends how it sounds and the power.
Either way I got it for free off of someone locally.
thats probable the cheapest route to go.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Rapidfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys, 160* stat
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
15s are cool!
AIM: MustangEater82
Old Aug 4, 2002 | 03:20 PM
MysticTeal 95 V6's Avatar
Post
I'd do what the other guy suggested, then take that extra cash you would've spent on the catback and have a TransGo shift kit installed to make your 1-2, 2-3 shifts feel a little more firm. Maybe have a tranny cooler installed at the same time. You can also do the TB bypass for the hell of it since it'd cost you next to nothing. A set of underdrive pulleys also?
All of the mod's mentioned above would run you under 400 bucks easy.
Old Aug 4, 2002 | 04:05 PM
nikkev's Avatar
Cool
To get rid of that flat spot from 25-35 mph,you need to open up the intake and exhaust.I had a free-flowing muffler installed right after I bought the car and I always thought "I have the muffler,why get a cat-back"?Anyway.the last year I owned my car I bought and installed a cat-back from a 1998 SS.That mod really surprised me.The normal "dead zone" that the 3.4 has was almost completely gone!Even my ex (still wife at the time) commented on the cars improved performance.I didn't even tell her I had done anything to the car.Anyway,a good shift kit ($100),underdrive pullies ($75),a take-off cat back ($50),and the free mods will get you a lot of performance gain.You won't be smoking V8's but you will be a lot happier with your ride!Good luck.
Kevin
1998 Black Z28 A4
-------1/8-------
8.584 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
Old Aug 4, 2002 | 04:44 PM
PitySister's Avatar
Post
i wonder if there is any place on the net i can get a replacement catback for a 1995 SS on the net....carparts.com maybe? just in case the local junkyards don't have anything....will they swap right on?
what kind of shift kits do you guys recommend??
thanks a ton for the help!!! i'm sure i'll think of more stuff later
Old Aug 4, 2002 | 09:07 PM
Sixer-Bird's Avatar
Post
Try SLP ( www.slponline.com) They will have SS and WS6 take-off parts. Also, just so you know, they didn't make SS or WS6s until 96. But don't worry, any year take off cat back should work for your car. I used to have a 95 3.4L 5 speed Bird, so I know what you mean by sluggish in 3rd to 4th. The mods nikkev suggested should wake it up a bit.
-Joshua
1997 Bright Red Trans Am WS6 M6
I was thinking dagger. -Steve Nash
Parts Wanted
May 1, 2016 10:25 AM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ericksd
Jan 20, 2016 06:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
