LT1 vs. Turbo Talon
LT1 vs. Turbo Talon
I was on my way home on Friday night and ran into a talon he took the same exit as me and we toyed around for a while until we got to a straight open road. He downshifted and I floored it We went to about 120mph before we shut down I barely edged him out (His nose was at my the back of my front fender). We pulled off to a gas station and bs'ed for a bit. I think he said he was running 17 psi and had a different turbo. I don't if he was telling the truth or not. DSM guys chime in and tell me if that is about right. By the by I have slp headers, random tech catback, orp, and programming.
Boost is set to 10-11lbs from the factory, factory pistons can handle 24-26lbs, the headgasket becomes a problem after 22lbs. With a triple layer metal headgasket and arp head studs, it's not a problem to run 24 pounds as long as you're not leaning out too much and everything else is good.
Boost != horsepower on a turbocharged car. Flow is very important, and when switching turbos, psi becomes irrelevant.
Originally posted by djc485
WHy does the psi become irrelivent? Is it because the turbo spools faster?
What year was the Talon? The first gens are quite a bit lighter (90-94) and have better turbo's from the factory. If he upgraded to a 16G turbo with some bolt-ons and 17psi, he would have no problems keeping up. My other car is a 92 Talon.
Mike
Mike
It was a newer pne with the high-rise spoiler. I was just shocked when this happened especially from a roll, usually I walk all over those cars. Another random question. How do you turn up the boost on a stock turbo, is the something tha tblocks or controls the air flow into the turbo?
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
