Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
how fast are the mach 1's
Old Apr 20, 2005 | 06:58 PM
  #61
Roller406Bu's Avatar
Re: how fast are the mach 1's
Originally Posted by Angus
Although I do agree that LS1's take to mods very well, I diagree with pretty much everything else in the above statement.
I just trapped 112.35 mph this weekend (short-shifting about 500 rpm too low ) with an entirely stock long-block & no power-adder of any sort.
There's a lower ET + higher trap speed in the car just as it sits with the proper shift points.
My only "power" mods are:
Dyno Tune
Cold Air Intake
Cat-Back Exhaust
X-Pipe with catylitic Converters
Mid-Length Headers (I could add long-tubes for more horsepower/torque BTW)
My 15,000 mile '03 4V has never had the valve covers off & the only thing that's changed internally since Ford made it has been the oil.
IMHO, LS1 cars are impressive without a doubt, but they are certainly NOT "unstoppable"...
Exactly....Nice times.......4v's
Old Apr 20, 2005 | 07:40 PM
  #62
robb4964's Avatar
Dyno Tune
Cold Air Intake
Cat-Back Exhaust
You trapped 112 on pump gas?..Stock cam? ..>WOW...I have never ever heard of that. 112 is a damn good trap speed indicating nearly 400 crank HP. That is very very hard to beleive man. Not to call you a lier but I dont see how your 4.6 could possibly have 400HP as is. When I say unstopable I mean mod for mod.
112 is extremely impressive.
Old Apr 20, 2005 | 07:49 PM
  #63
Angus's Avatar
Thanks for the compliment(s).
Yep - 112.35 mph on 93 Octane pump gas. Stock cam(s) and all.
Time Slips from 04/16/05
I'm actually a little disappointed in the trap speed - I was expecting 113 - 114 mph.
I set my shift light to 6200 by mistake instead of 6700 like I should have & didn't notice it until I was done racing.
Old Apr 20, 2005 | 07:51 PM
  #64
ls1650's Avatar
Originally Posted by z28stanger
Where are you getting those numbers?????? Mach 1's are rated at 330hp and will wipe the floor with a stock ls1. That 305hp might be for an automatic, but not a stick.
first of all a STOCK 03 mach 1 does not have 330hp! it comes 305hp from the factory and that is not dyno! it is 305hp at the flywheel. i advise u to look n read this information and faqs about the mach 1 before saying anything!
http://www.mach1registry.com/FAQ.htm
that site has all the information u need about a mach 1.
it don't matter whether a mach 1 is manual or automatic, it will still come with 305hp stock! so your saying a mach 1 with automatic has 305hp and a mach 1 with manual has 330hp? are u stupid? u need to read your faqs!!
Old Apr 20, 2005 | 07:55 PM
  #65
ls1650's Avatar
My Mach dynoed 282 rwhp/305 rwtq completely stock right down to the paper air filter.
After calculating % of driveline loss (~15%) that's ~ 332 crank hp & ~ 359 crank tq. Quite a bit higher than the (conservative) factory rating.
MANY other 5-speed Mach 1's have dynoed the same - or higher - than my car BTW. My dyno numbers are probably about average.
Nice that Ford started under-rating their motors like GM did for years...
hey buddy i was talking about coming straight from the factory stock! i wasn't talking about dyno. ofcourse if u dyno your car u will get low number and that is because your stock from the factory comes at the fly wheel.
Old Apr 20, 2005 | 07:59 PM
  #66
robb4964's Avatar
HOLY COW!!!!!now I know why you trapped so high. You pulled a 1.6 sixty...I was confused fro a minute. But apparently you made good use of the power you have so it all makes since. I wouldnt know what its like to pull such a good sixty. My rear end would snap like a twig If I even attempted a 1.9.
Nice times!!!
Old Apr 20, 2005 | 08:00 PM
  #67
robb4964's Avatar
Man...This is uncalled for. Pipe down. Name calling is rediculous and not necassary.
Old Apr 20, 2005 | 08:04 PM
  #68
robb4964's Avatar
Angus understands you where not talking about dyno. I think youn are the one not understanding. If you do the math assuming drivetrain loss with his dyno numbers he is pushing nearly 330 crank HP.
Just like LS1's they have been underated. LS1's are supposed to have 305 at the flywheel as well but have more like 350+ using dyno numbers and percentages to calculate the Amount of power.
Coming frmo a LS1 man thrue and thrue I can tell you the Mach1 is an underated car.
  #69
Angus's Avatar
That information was/is provided by Ford Motor Company.
It's a well-known fact that the '03/'04 Mach 1 4V's were under-rated by just a bit.
I owned an '01 Cobra - rated at 320 crank hp/320 crank torque - right before my Mach.
I had both cars dynoed when they were completely stock - right down to the paper air filter.
Here's what the '01 Cobra vs the '03 Mach dyno looked like.
Funny how the '03 Mach power & torque curve are ABOVE the (officially) higher rated Cobra 4V...
Also, divide the Cobra's 273.3 rwhp by .85 (for 15% driveline loss) & it equals ~ 321 crank hp, which is pretty close to the 320 hp that Ford rated the 4V in '01.
Now divide the 281.6 rwhp by .85 & it equals ~ 331 crank hp.
That's about 25 hp higher than Ford rated the 4V in '03.
Just as an FYI - I've been a member of Mach1registry.com since August of '03 (the month before I bought my Mach ) & I have almost 1000 posts on that fine site.
I think I know a little about what information is posted and/or available there...
Another FYI - don't believe EVERYTHING you read on the internet.
MANY internet sites still state that all Mach 1's had/have a cast-iron engine block - probably because Ford's own press release stated so & has never been corrected.
I know for a fact that ALL Mach 1's have aluminum engine blocks, not cast iron though.
So much for "Internet-Accuracy"...
Old Apr 20, 2005 | 08:05 PM
  #70
ls1650's Avatar
im just proving my point and correcting what he said was wrong
Old Apr 20, 2005 | 08:09 PM
  #71
Mikie's Avatar
Guys,
Not really any sence in dragging this discussion on and getting bitter, but to add...
I dont believe the Mach has 330 fwhp , but it should have a touch more than 305 as it IS underrated like the LS1. Im thinking somewhere in the ballpark of 312 fwhp. Take away the driveline loss percentages and it would about equal on average 280-285 to the wheels(STOCK).
Old Apr 20, 2005 | 08:14 PM
  #72
Mikie's Avatar
Damn,
After re- reading Angus' link.... Maybe they do have 330...lol
Old Apr 20, 2005 | 08:17 PM
  #73
robb4964's Avatar
Originally Posted by Mikie
Damn,
I think they are pretty close. Im sure some have more power then others.
But Numbers dont lie.
Old Apr 20, 2005 | 08:18 PM
  #74
Angus's Avatar
Talking Re: how fast are the mach 1's
Seems to me like all you have is your OPINION which is based on little/no verifiable and/or accurate data.
I provided measurable/quantifiable/verifiable FACTS however to prove that I'm right...
Old Apr 20, 2005 | 08:23 PM
  #75
Angus's Avatar
As far as I've seen, the lowest manual-trans dyno has been ~ 273 rwhp & the highest has been 291 rwhp.
Considering how much cars and dynos can (& do) vary, the power range seems pretty much within the norm for a production vehicle these days...
