Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
Chassis Dyno Today!
Old Dec 13, 2014 | 05:32 PM
Steve69SS396's Avatar
Chassis Dyno Today!
I'll be replacing the old AFR 210 heads on my 427SBC with some AFR 245's. The new heads and rockers are due to arrive next week. I did have this motor run on an engine dyno last year and it made 640HP and 565 torque with an air fuel of 12.9. The car has a TH400, Coan 8" converter and 9" Ford.
Before I swapped heads I wanted to find out how much the current setup put to the tires. It made 471RWHP and 401 torque with a fat air fuel ratio of 12.0. After I swap the heads I'll take it back to the same dyno to see how much it picked up.
Several years ago when my car had a 357 in it, it made 382 on this same dyno. That setup ran 11.20's at 119 with a best 60ft of 1.58. The current motor has only been to the track once for motor passes and it ran 10.41 at 128 with a 60ft of 1.51.
Here's the dyno video:
Old Dec 14, 2014 | 12:21 AM
Re: Chassis Dyno Today!
Just got the dyno chart for the 2 runs.
Old Dec 14, 2014 | 12:40 AM
Old Dec 16, 2014 | 02:24 PM
Impressive numbers, and great track times/MPH.
Are those dyno and chassis numbers basically for the same configuration and correction conditions? If so, the drivetrain losses look high (26.4%), but auto transmissions are not my strong point. Part of that could be attributable to the large tires, and I guess the 9-inch.
I know nothing about auto trans setups, even though I run a TH400. When the engine was originally built, it had a T56 behind it, and the losses were 12.1% (670/762 on spray), through a 12-bolt. When I got tired of screwing up shifts and abusing the rear with 5,000 RPM clutch dumps, I had the TH400 installed, and it cost an additional 75 HP loss (595/762), for 21.9% loss. Both the chassis pulls were on street tires, so they were comparable.
The shop told me that was a surprisingly low loss for the TH400 with a non-locking converter, and indicated the converter was apparently "very tight". It's an ATI converter, but I don't know the diameter. I guess they were expecting something more like 25%.
Unfortunately the engine has more dyno time than track time, basically collecting dust in the garage for the past 10 years, due to a job that runs 11 hours/day and another 1/2 day on Saturday. Sounds like you put yours to a much better use.
Good luck with the future upgrade.
Old Dec 16, 2014 | 08:11 PM
If I leaned mine out from the 12.0 AFR on the chassis dyno so it was the same 12.9 as it was on the engine dyno, it should pick up some RWHP which would reduce the calculated losses.
Did you happen to get any 1/4 mile times with the stick and the auto?
Thanks!
Old Dec 17, 2014 | 11:25 AM
ET's were different, but MPH was basically the same TH400 or T56, running without the nitrous. They would both produce 117 MPH, and the TH400 was a consistent 11.5, but the M6 was all over the place, depending on how hard it launched and how well I shifted. Traction was never an issue.
Running with a 125-shot on the TH400 the MPH picked up to 127.7 but the ET only dropped to 11.1. It was a problem with a soft launch. The converter was sized to flash to 5,000 RPM at 750-800 lb-ft on the 300-shot, but it turned out to be a dog with the 125-shot. The RPM didn't rise fast enough, and the ECU programming kept the nitrous from flowing until it reached 4,500 RPM.
Someday, I'll run it with the 300-shot. I'm retiring in 2015, and the first thing I do is get the car back on the street, and to the track.
Old Dec 17, 2014 | 02:31 PM
What you saw on the motor is consistent with what I've seen. Your speed doesn't indicate that the standard trans has more HP than the TH400 but Dyno's for some reason show a large difference. Running consistent ET's is more difficult with a stick. Unless you are somebody like Ronnie Sox!
Old Dec 23, 2014 | 08:46 PM
New heads arrived today. Still waiting on the T&D shaft rockers.
Old Jan 14, 2015 | 11:15 PM
T&D steel body shaft rockers finally showed up today.
Old Jun 12, 2015 | 06:01 PM
Well, a lot has happened since January. Got the motor ready to pull back in February. The following week I broke my leg when I crashed on my dirtbike. Finally get the motor out at the end of April and decided to check the bearings. All of them were great except 1 rod bearing that was about to spin. Didn't damage anything but had to take the motor completely apart to make sure everything was good. Motor is back together now, just waiting for the rebuilt lifters.
Old Jun 12, 2015 | 06:31 PM
Klypto's Avatar
beautiful
Old Jun 21, 2015 | 12:13 PM
Originally Posted by Klypto
beautiful
Thanks!
I got it fired up this morning. Need to wrap up a few things before I can drive it.
Old Jun 21, 2015 | 01:15 PM
That thing really sounds evil. Great job.
Old Jun 21, 2015 | 01:59 PM
Thanks!
Old Jul 31, 2015 | 09:16 AM
Pullngz's Avatar
That thing sounds awesome! It's been a while, made any trips to the track? Dyno? How does is feel?
