Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
5.0 vs LT1
Old Mar 14, 2008 | 02:33 PM
  #16
buzz12586's Avatar
I have a slow LT1 you can run.
Old Mar 15, 2008 | 01:19 AM
  #17
sn8ke eatr's Avatar
army have you ever run your car at a track? dont call it a 12sec car till you know it is. im just saying because ive owned a 5.0 and i liked it but it was far from a 12 second car. from what you've described, unless you put it on a serious diet i highly doubt your in the 12s, not on those tires anyway. the fact that your car beat a lt1 i can see, the way you say you train legnthed him is what im calling BS on. i just don't see it happening is all.
Old Mar 15, 2008 | 09:13 AM
  #18
roadwarrior's Avatar
props on the kill, your stang must be set up and tuned good cause the 2 built 5.0's im used to running around here both have longer laundry lists than you but even the stroker falls short everytime.
Old Mar 15, 2008 | 12:40 PM
  #19
DarkHorse's Avatar
Amazing, I had a ****load of stuff on my Fox and it cracked 12.9 1 time n/a
Was a solid 13.teen car tho
Old Mar 15, 2008 | 09:01 PM
  #20
DarkHorse's Avatar
1986 Mustang GT
302cid
Bryans All Pro Transmission built AOD
DirtyDog 3800 converter
TEA Ported Trick Flow Twisted Wedge heads
1.6 Rockers
Explorer intake
70mm Throttle Body
MSD Ignition
Underdrive pullies
Mac shorty headers
Off road H pipe
Flowmaster cat back
UPR Pro lower control arms
4.10 gear
Griffon aluminum radiator
Strange 10 way adjustable front struts
QA1 coilovers 200lb spring
Strange 10 way adjustable rear shocks
Summit Sport rims 15x4 w/ General 165R15
Summit Sport rims 15x8 w/ Hoosier QTP 26x11.5x15
60' - 1.8369
ET - 12.9420
MPH - 104.63
DA - 3355
246rwhp
318rwtq
Car weighed 3140 w/me and 1/2 tank
13.teen-13.20 car on average
http://media.putfile.com/DarkHorse-run-5-9-22-07
Old Mar 15, 2008 | 11:07 PM
  #21
LSWHO's Avatar
I've always heard an HCI 5.0 with traction is a 12 second car. "Pretty easy."
Old Mar 16, 2008 | 12:52 PM
  #22
CANTONRACER's Avatar
Have not changed your sig yet eh?
Old Mar 16, 2008 | 04:54 PM
  #23
buzz12586's Avatar
So do you actually have a 12 second time slip?
Old Mar 16, 2008 | 05:01 PM
  #24
DarkHorse's Avatar
Originally Posted by Army4life
Sure is.
But I think our buddy Darkhorse had too much gear.. I can't fathom why his et's were so slow for what he has done.
My only guess is the 410's are WAY too much for that aod
Errr - 4.10's with an AOD are too much now? I could have sworn in some thread you stated you have knowledge with these Fox cars?
If I had to guess why it was so ''slow'' I'd go with - 246rwhp/318rwtq - but that's just my opinion. I feel the car was maxed out for being an untuned speed density car, she gave all she had and squeaking a 12 second slip was pretty good for the mods.
Hell I HAVE a 12 second slip, but I don't claim to have a 12 second car because it was never backed up.
There's plenty of Mustangs in our area and while I love the body style - half the time they dont' run as well as you may want to lead yourself to believe.
My Z28 slaughtered many a 'stang around here. No comparison.
Old Mar 16, 2008 | 07:27 PM
  #25
scott9050's Avatar
4.10's are not too much on an AOD car and its 2.40 1st gear by a stretch. I said it before, I think the Explorer intake unported was a mismatch for the ported heads. That and the speed density that was mentioned and stock cam? By the way Army, do you have some pics of that car of yours? I would also like to see a few copies of the slips (I am assuming there is more than one). You make a lot of claims but I have yet to see one single thing to back any of it up.
Old Mar 16, 2008 | 07:47 PM
  #26
DarkHorse's Avatar
My new setup is even worse IMO
Stock GT lower intake - TW heads - Boxed upper intake.
I need to have the lower intake ported but it's what I have right at this moment.
The turbo should still be able to force the air in pretty good for the time being.
Old Mar 17, 2008 | 07:00 PM
  #27
buzz12586's Avatar
Oh well in that case I have an 11 sec car now. With the MPH it should run 11's, it just needs a better 60ft to do so. But I guess that means I can tell people I drive an 11sec car.
Old Mar 17, 2008 | 08:42 PM
  #28
In the 1/8th......
Old Mar 18, 2008 | 06:23 AM
  #29
tomcowle's Avatar
I see Army used the old "slipping clutch" excuse, that is a term worn out by the 5.0 world when they get beat or when their stuff doesn't run as good as their mouths do.
I've owned a ton of 'stangs so I'm hip to the lingo.
2.73's, slipping clutch, full weight car equal 12's??????
Old Mar 19, 2008 | 06:02 AM
  #30
Do you have a timeslip even for the 1/8 or did you G-Tech the car?
