Will traction bars
Old Apr 11, 2006 | 01:25 PM
ZL1modified's Avatar
Question Will traction bars
really eliminate wheel hop?
If Yes.
I would like to know who makes the best? and where the best place to get them is?
Old Apr 11, 2006 | 01:56 PM
teke184's Avatar
Re: Will traction bars
would help to know what kind of car you're talking about.
from your list of mods, i suspect its a 4th gen
and if by "traction bars" you mean lower control arms...the answer is YES
the bushings are stiffer as is the body of the unit itself. both will reduce deflection under load and help plant the rear tires better.
for a good street/strip setup...look into the BMR poly/rubber combo for the LCAs...less likely to bind on the street but still a huge improvement over stock
Old Apr 11, 2006 | 02:08 PM
Sorry about excluding my car.
however your right. its a 97 z28, auto
Old Apr 11, 2006 | 03:41 PM
ABA383's Avatar
I see you are in PA...What part? I can show you my set up which is mostly Spohn stuff, out of Lebanon, PA. I'm near Gettysburg...
--Alan
Old Apr 11, 2006 | 03:52 PM
Traditional "traction bars" are generally used on leaf spring cars. Bars like the Lakewood "traction action" bars are made for the 4th Gens, but they really don't work. The stock style suspension, with various upgrades for the LCA's, torque arm, etc has pushed these cars to 1.2x 60-ft times. You don't need to go beyond the parts that companies like Spohn make.
Moving to the "Suspension........" forum.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
Aug 5, 2015 08:35 AM
SpeedJunkee
Jul 19, 2015 09:06 PM
