will this axle fit?
Old May 18, 2009 | 11:17 AM
ascastil's Avatar
will this axle fit?
Will a 92 axle fit onto a 97 Camaro Z?
Old May 18, 2009 | 12:29 PM
$hawn's Avatar
I believe their about 2 inches or so shorter.
Old May 19, 2009 | 12:33 AM
It fits - direct bolt-in, but as noted above, they are 1-1/2" shorter PER SIDE. That would require using rear wheels with close to 0mm offset (vs 55mm on your 4th Gen wheels), or adding 1-1/2" adapter/spacers with your 4th Gen wheels. Would not have the ABS provisions. Not sure about the disc brake mounting plates.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
May 12, 2015 06:19 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
