wierd brake issues
Old Nov 19, 2007 | 10:26 PM
Malice 1's Avatar
wierd brake issues
My brakes stop my car just fine, but I have an "ABS INOP" light illuminated on my instrument panel, as well as a red "BRAKES" warning light.
My exterior center brake light (the one in the spoiler) doesn't illuminate, even after replacing the bulbs. The other two exterior brake lights illuminate.
I just recently replaced my rear pads and rotors, and the red "BRAKES" light on the dash illuminated a week or so after I did that. The ABS INOP light has been on since I bought the car.
I'm betting that all of these faults are interconected. Does anyone have any ideas? I did a search on the issue and found that most ABS INOP lights are caused by dirty sensors, but I also found that the center rear brake light and the ABS are connected.
Old Nov 20, 2007 | 01:46 PM
OBE1 95Z28's Avatar
Check your fuses.
Old Nov 20, 2007 | 03:50 PM
Malice 1's Avatar
I've checked them. They are all in good shape.
Old Nov 20, 2007 | 04:05 PM
The "BRAKE" light comes on for two reasons.... 1) the e-brake is on, 2) there is unequal pressure in the front and rear braking systems. If the light came on shortly after you replaced the rear pads and rotors, I would look for leaks at the rear rotors, and check to make sure that you didn't get some air in the system.
I suspect that once the "BRAKE" light comes on, indicating there is a possible fault in one-half of the braking system, the ABS is deactivated.
Old Nov 20, 2007 | 04:16 PM
Malice 1's Avatar
I'll bleed out the system and see what happens. The ABS INOP light has been on since the day I got the car, so I believe the two brake issues might be unrelated.
I remember hearing once that the ABS system in somehow connected to the 3rd brake light located in the spoiler. If one failed, the other failed.
NewsBot
Apr 9, 2015 07:10 AM
dluna333
15
Mar 13, 2015 12:30 PM
rwferguson43026
Feb 6, 2015 10:06 AM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
